Graphics problem in some games Please Help!
Hey there i have a really annoying problem with my graphics in some games and it looks like this http://postimage.org/image/l20hrqt2r/ or this http://postimage.org/image/q7qx6xjv5/ and it is very annoying it started happening after i accidentaly hit reset to default in my bios settings, the grass and the trees in the games just look horrible like there is no AA or something i dont know i have a EVGA GTX 670 SC video card and a Intel Core i7 3770K 3.60ghz CPU. Please help it is so annoying ill do anything to fix it even buy a new graphics card please help ):
6 answers Last reply
More about graphics problem games help
  1. Chill. This must be a software problem, and it's got to be pretty easy to fix. Which BIOS did you reset to default, the motherboard's or the GPU's?
    I dont know it wasnt in the advanced part of the bios it was in the normal part of it, it just said it off to the right and i accidentaly clicked it so maybe both? im not sure
    Don't...
    Bump posts
    http://www.tomshardware.com/forum/283384-33-read-first
  3. If it had a GUI it was the motherboard BIOS. Bring your 3770K back up to 3.6 ghz and make sure the game has AA turned on, then check out the Nvidia Control Panel if that doesn't work and force AA on.
    What does bumping posts have to do with this thread?
    Ok i checked and it as at 3.6ghz already and i have tried forcing AA and i know AA is on in game and before i did the bios thing that game looked great without any of the nvidia control panel options So what now ? ): Also i have no idea what the bumb thing is :P
    You made two "bump" posts and if you make a third I may ban you, then you'll know for sure what the "bump" thing is.
    Well sorry i dont know what that is im just trying to get help
Nvidia Games Graphics
