Approximate Purchase Date: e.g.: this week (the closer the better)
Budget Range: 400ish before after shipping the lower the better
System Usage from Most to Least Important: gaming (mainly mmos, maplestory mostly), web, video (maybe hd), word processing, some transcoding from pc to ps3
Are you buying a monitor: NO (i have a 720p tv, but when i use my ps3 i get a 1080 signal so im not sure if it can do 1080 or its just saying that 1080 is the resolution recieved and it scales it down to 720)
Parts to Upgrade: Whole System
Do you need to buy OS: No
Preferred Website(s) for Parts: newegg.com (really were ever will be cheapest and quickest)
Location: City, State/Region, Country - Florida, United States
Parts Preferences: I know Maplestory and most mmos are not really GPU dependent , so i was really wondering wether or not to go for an apu and or an i3 or a pentium. I would also like an ssd and 8gb or ram
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: as stated above my tv a (samsung ln32d450) is boxed as a 720p tv but ps3 outputs a 1080p signal so im suring you guys know better than I.
Additional Comments: i know its a stretch as quiet and cheap do not go together but i would like it to be kinda queit if that is ann option.
My current pc is an intel pentium 4 1.59GHz willamette as stated by cpu z. So anything will probably be a massive boost in performance. It stutters playing youtube videos muchless while transcoding video or playing a game (which i have been unsuccessful with)
And Most Importantly, Why Are You Upgrading: I only have like $410 so if the build could be less than 390 it would be AWESOME. Im a practical person so i know i will not be encoding 4 hour long movies from mp3 to h264 in 35mins but i would like to be able to play maplestory and other low req games without lag. Thank You here is a build i did on newegg.
Case: Antec Gaming Series one illusion
Power Supply:CORSAIR Builder Series CX430 V2
Memory: CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
SSD: OCZ Synapse Cache SYN-25SAT3-64G 2.5" 64GB
MotherBoard: ASRock A75M-HVS FM1 AMD A75
CPU: AMD A8-3870K Unlocked Llano 3.0GHz Socket FM1 100W Quad-Core Desktop APU
Total: 370 (but there is a combo with the cpu/mobo which brings price to 360 or so)
Thank You all for your input and help.
Overclocking: Maybe
