Fan speed controller for 3 pin chassis fans
I have recently purchased a Asus Maximus IV Gene-7/Gen3 MoBo with an Arctic Freezer 11LP CPU fan and Itel i7 CPU. The case is a SilverStone GD05 which comes with 3 120mm chassis fan with 3 pin connectors. I added two 80mm exhaust chassis fans to the case as well. The MoBo has fan control in the BIOS for any 4 pin PWM connector going to 4 chassis fan connectors. However, only the Arctic Freezer has a 4 pin connector. How can I control the RPMs on all of the chassis fans that only came with 3 pin connectors? I have enough connectors on the MoBo but they are for 4 pin connections. Appreciate any feedback as this is my first build. Thanks!
1 answer Last reply
More about speed controller chassis fans
  1. http://www.nzxt.com/new/products/fan_control/sentry_mix
    Getting a fan controller will help heaps :) The only other option is to get fan resister cables to reduce the RPM, however, you have no control over what RPM you would want them to spin at.
New Build Systems
