Solved
Will this power supply fit
13 answers Last reply Best Answer
More about will power supply
  1. Yes, it will fit.
    Be careful though, a lot of higher-end GPU's require a more powerful PSU in your rig.
    What CPU and GPU are you looking to run?
    *edit* the link took me to a 430w.
    A 600w Corsair is plenty of power.
  2. 600 watts will be fine for the large majority of builds.
  3. yes fits and g00d
    The link went to a 430w CX for me?
  5. GRIZZLY629 said:
    The Cooler Master Elite 431 Plus (RC-431P-KWN2) accepts power supplies that meet the Standard ATX PS2 / EPS 12V physical dimensions (i.e. 5.9"(W) x 3.4"(H) x 5.5"(D) / 150mm(W) x 86mm(H) x 140mm(D)).
    The Corsair Builder Series CX430 (SKU# 75-001666 / CP-9020046) power supply's physical dimensions, according to Corsair, is 5.9"(W) x 3.4"(H) X 5.5"(L); 150mm(W) x 86mm(H) x 140mm(L).
    The Corsair Builder Series CX600 (SKU# 75-001668 / CP-9020048) also has the same physical dimensions.
    Looks like a perfect fit to me.
  6. yar
  7. Thank you for the fast reply I was really worried about this. The cpu I was looking to run is the i5 3450 because that's what came with the computer and the gpu is the XFX Radeon 7750 :)
  8. also my bad I should've said about the size option
  9. sounds g99d
  10. Best answer
    For a system using a single Radeon HD 7750 graphics card AMD specifies a minimum of a 400 Watt or greater system power supply. The power supply should also have a maximum combined +12 Volt continuous current rating of 20 Amps or greater.
    Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Sufficient Total Combined Continuous Power/Current Available on the +12V Rail(s) rated at 45°C - 50°C ambient temperature, is the most critical factor.
    The Corsair Builder Series CX430 (SKU# 75-001666 / CP-9020046), with its maximum combined +12 Volt continuous current rating of 32 Amps is more than sufficient to power your system configuration with a single Radeon HD 7750 graphics card.
    The Corsair Builder Series CX600 (SKU# 75-001668 / CP-9020048), with its maximum combined +12 Volt continuous current rating of 46 Amps is way more than sufficient to power your system configuration with a single Radeon HD 7750 graphics card.
  11. Best answer selected by GRIZZLY629.
  12. Thanks everybody Ill get the CX430
  13. cooli0
Power Supplies Cases Components Product
