Sign-in / Sign-up
Do any any of these parts not go with each other and will they run any pc games
  • New Build
  • Systems
  • Product
Last response: in Systems
September 22, 2012 5:29:39 AM
This is the system I plan on buying and putting together, I am in need of suggestions
Memory:crucial m4 64gb ssd, 1tb hdd samsung spinpoint f3 7200rpm
Ram: x2 4gb Kingston DDR3 1333 MHZ
PSU: Seasonic M12II Bronze 520w
GPU: Msi R7870 Twin Frozr 7870ghz 256-bit
Socket: 1155
Cpu: Intel i3 Core processer
Mobo: Asrock 268 Extreme3 gen3
The games I really have my mind set to playing are Dayz(the arma 2 mod), minecraft, and WoW. I am on a fairly tight budget, not including the operating system, keyboard, mouse, or monitor, Im willing to spend about 500-650 dollars. I will gladly take suggestions for improving performance or lowering price.
More about : any parts run games
September 22, 2012 7:09:35 AM
I'd get the Asrock H77M and make sure that the RAM is 1.5V or lower. For a case, I would get the Antec 302. Plus, DayZ works better on i5s or better.
m
l
September 22, 2012 2:29:31 PM
Thanks for the quick replies , I'll consider it and hopefully have my pc running soon
m
l
September 22, 2012 2:54:11 PM
I will definitely get the suggested motherboard, but you must remember, I am on a tight budget and buying the i5 nearly puts me over. So I was wondering where I could get these parts cheaper prefferably in bundles.
m
l
September 22, 2012 6:11:14 PM
What's the difference between a computer with all the parts listed above and simply buying an amd quad-core a6 processor computer for $100 less than it would cost to build the other one
m
l
