Solved
Graphic card help
hi all,
i want to buy a gc within 8-9k budget but still confused... amd/ati gc's use 450w and nvidia gc use 350w... so m planning to buy a 450w psu and later buy the gc after deciding... what i fear is that won't 450w gc cause any problems to my gc in case i buy a nvidia one which uses 350w power supply... or extra power doesn't matter... help me out...
9 answers Last reply Best Answer
More about graphic card help
  1. Quote:
    I am not sure what you are asking. Are you saying that you have 9 grand to buy a pc with? If so, you will need a bigger power supply to run all of the stuff you can buy with all that money.
    No doubt. But if you meant 800-900 then you could probably look into a 560 ti or 570.
  2. Are you in India by any chance? Because 8k-9k rupees would actually make sense.
  3. 9k for a GameCube? I don't even have one but I'll sell you anyway.
  4. Why cant people convert their budget to USD since most of us deal with USD?
  5. I am from India so you can assume 165 dollars
  6. well i bought a corsair 430w psu and going for zotac nvidia 550ti finally
  7. Best answer
    Ok much better. You'd be looking at the radeon 7770, it is very easy on power supplies and leagues better than the 550 ti. It never can hurt to have a higher watt power supply except in efficiency in very high watt units. Don't get a 350w unit, 450w can handle most everything low-end these days but 350 can be borderline.
  8. Best answer selected by shivamkss.
  9. He should be able to afford the 6850...which is a decent bump from the 7770...
Graphics Cards Nvidia Graphics
