New HTPC build :
A6-3500
ASRock A75M
GSkill 4GB Ram
Corsair 430 builder series PSU
Got it all together last night, windows installed perfectly. However after powering off it will not power on. I can see the CPU fan cuts on very low RPM when I press the power button. Will not turn back on until I cut the main power fully. At first I thought it might be a heat issue so I let it sit off all night, but same situation this morning. Reset button also works perfectly fine. Not sure where to go with this on a new computer.
A6-3500
ASRock A75M
GSkill 4GB Ram
