I finished building a desktop yesterday, and it all worked out well apart from a few issues with my graphics card. I have installed the latest drivers to the best of my knowledge (from here) a couple of times and reinstalled windows once.
Firstly, Catalyst Control Centre isn't detecting the correct resolution for my monitor (22" 1920x1080) and I am unable to select the correct resolution in the control panel. I eventually worked out that I can manually change the resolution through CCC but I have to do this every time I restart the computer. After a reboot it defaults to 1600x1200.
Secondly, my second monitor is not being detected at all. The first one is plugged into the DVI-D port on the graphics card with a DVI-D to VGA adaptor that came with the graphics card, and the second is in the VGA port on my motherboard (Asus P8Z77-V LX) as the graphics card only has 1 DVI-D, an HDMI and 2 Mini DisplayPorts. The monitors do not support HDMI. Both screens and cables have been tested on the working port, and they work.
I am terrified that I have bought wrongly, as I have spent a lot of money on this build and cannot afford to replace any parts. Please help me with these problems guys.
