Solved
Will these fan connect to the NZXT Phantom fan controller?
Like the title asks, will these fan connect to the NZXT Phantom fan controller? (hope this is the correct section for this question)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835494004
Here is a picture of the NZXT phantom fan controller cables
http://www.techpowerup.com/reviews/NZXT/Phantom_Hale90/images/innercablefans.jpg
2 answers Last reply Best Answer
More about will connect nzxt phantom controller
  1. Best answer
    It actually doesn't really matter if they fit or not, NZXT cases mounting points for fans are not accurate. The only fans that will fit in a NZXT case are NZXT branded fans.
    For some reason NZXT fans are smaller than the standard fans, and the holes will not align.
    any of the NZXT fans will fit, i would buy matching ones to whatever came with the case.
    I am glad you posted this here, as i ran into the same problem trying to put in couple of other fans that i had lying around.
    source: i have an NZXT phantom.
  2. Best answer selected by sinister8102.
Homebuilt Connection Fan Fan Controller Systems Product
