Are these parts all compatible?
Athena Power CA-GSB01DA Black 0.8mm SECC Steel ATX Mid Tower Computer Case
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
MSI N570GTX Twin Frozr II GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
OCZ ModXStream Pro 600W Modular High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Intel BOXDH67BLB3 LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Intel Core i5-2400 Sandy Bridge 3.1GHz (3.4GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000 BX80623I52400
Microsoft Windows Anytime Upgrade: Windows 7 Home Premium to Professional
Am i missing anything ? is everything combatlbile? i plan on mostly playing bf3 on it, can it handle BF3? what setting if so could i get 60 fps?
and do i need a wireless adapter to get wifi on this build?
2 answers Last reply
More about parts compatible
  1. What are the prices for those parts? Because there are a few parts I would not recommend you get. With that case you can only put the psu on the top thats not good. Don't get a 570 unless you get a great deal. Instead get a hd 7870 or gtx 660. They are better cards, use less power, make less noise and run cooler. Ocz modxstream aren't very good psu they're not bad but you should get a corsair, antec, or seasonic 500w psu. You will need a wireless adapter to get wifi.
  2. its compatible, its just not maximizing price to performance at all though.
New Build Systems
