Solved
Help me choose a graphics card among these two!
1)NVIDIA GeForce GTX 550Ti 1 GB GDDR5
2)Sapphire HD 6750 1GB GDDR5
which would be better for my AMD phenom x4 9650???
games like crysis2 and witcher should be played with high graphics...!
thank you sooo sooo much! :D
6 answers Last reply Best Answer
More about help choose graphics card
  1. Go with whats cheapest. Going to be held back by your slow quad core anyways.
  2. Best answer
    Are you sure you won't be able to opt for a better one?
    Judging by your budget, I can see a HD 7770.
    Here's one for about $115 after rebate.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102967
    To answer your question, they both perform almost neck and neck. It'll all go down to preference. :)
    so,
    i'd have problems in gameplay because of my quad core?
  4. Best answer selected by dojo52.
  5. thank you!!!! =)
  6. No problem. :)
Graphics Cards Graphics Product
