Solved
Ordering these parts in a week.
Anything I should change?
I'm a bit skeptical about the motherboard its a bit on the cheap side, is it OK or should I change it?
Also buying the CPU at micro center so it will be 40$ cheaper.
Thanks in advance.
http://pcpartpicker.com/p/igAb
PS I am an idiot who forgot to post the link.
12 answers Last reply Best Answer
More about ordering parts week
  1. I don't see any links.
  2. Best answer
    The B75 doesn't over clock so no real reason to get an unlocked cpu. You can pick up the 3450 at microcenter for a cheap $150. Also 630w is total over kill for one of those cards, look at a 500w - 550w psu although a 500w will run it just fine.
    If the mobo can't oc than I don't want it, any recommendations?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157304
  5. Why_Me said:
    Thank you sir.
    No more questions.
  6. Best answer selected by lemongrassgogolo.
  7. You can also downgrade the PSU to about 450-500W.
    630W is too much for your build.
    What if I want to upgrade/crossfire in the future? Won't I need a powerful PSU
    Also its only 60$
    Also its only 60$
    http://www.microcenter.com/product/387554/Z77_Extreme4_LGA_1155_Z77_ATX_Intel_Motherboard <---- it's $50 off that board if you bundle it with the 3570K (@ microcenter and it's a walk in deal only)
    Also its only 60$
    Ah, then by all means go get it. :D Although you -might- need something bigger than 630w by then.
    Hmm, upon checking, it seems your PSU has 50amps on the +12V rail. That's pretty impressive. Hopefully it can actually utilize most of that.
    http://www.amazon.com/Corsair-80PLUS-Certified-Modular-CP-9020015-NA/dp/B008RJZQSW/ref=sr_1_24?s=pc&ie=UTF8&qid=1346646210&sr=1-24 $86.00 & this item ships for FREE with Super Saver Shipping
    Corsair CX 750 Watts 80PLUS Bronze Certified ATX12V/EPS12V Power Supply CP-9020015-NA
  12. Eh... why quote me? :P
New Build Motherboards Systems Product
