PCIe 3.0 GPU, CPU only supports PCIe 2.0. Problem?
Greetings,
So I recently started picking out the parts for my first custom-built computer, using Tom's December $500 Gaming Build as a starting point. Here's a list of the components I've picked out thus far...
Case - Rosewill REDBONE U3 Black SECC Steel USB 3.0, eSATA, 3x 120mm Fans Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147160
Motherboard - ASRock B75M-DGS LGA 1155 Intel B75 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157335
RAM - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
CPU - Intel Core i3-3220 Ivy Bridge 3.3GHz LGA 1155 55W Dual-Core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116775
Graphics Card - PowerColor AX7850 2GBD5-DH Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131473
Now, the graphics card is a PCIe 3.0 x16 and from the information I've read at cpu-world.com, the CPU's "On-chip Peripherals" have "PCI express 2.0 interface" listed. What will the effects of running a this PCIe 3.0 x16 card be with this 2.0 CPU?
http://www.cpu-world.com/CPUs/Core_i3/Intel-Core%20i3-3220.html
3 answers Last reply
More about pcie supports pcie problem
  1. Not a problem.
  2. +1 for FinneousPJ
    At the most you may see a drop of a couple FPS other than that it wont touch the performance.
  3. There will be no performance.do not worry.
CPUs Product
