I am attempting to get a custom build PC done, not looking for anything fancy, here is what i am ideal use and what parts i have researched. i could use every ones input on cost cutting or recommended parts.
* i am located in canada, as much as our canadian dollar is worth more then USA, and USA prices are cheaper, ideally i dont want to have to deal with shipping/duty charges with warranty exchanges.
* budget i was aiming for around $1000 in for labour and parts
* main goal is to play borderlands 2, and diablo 3
* approx use, maybe 1-2 hours a day
* mainly for gaming, as stated before only really into FPS and RPG like skyrim/diablo
* don't plan on over clocking or upgrading ex/ dual video cards my goal is to build a pc that will run at full settings from the get go. i will worry about investing in a high end gaming down the road.
Parts (ive done some research and comparisons and i think i what i have chosen so fare is a fare priced item to quality ratio). stated before im canada, and really dont wish to deal with USA prices/custom even thow they are generally cheaper by about $10-$20. i think with the headache of wait time with shipping for warranty replacement is not worth the overall savings of maybe $100/$150.
CPU - i5 3570K $219
MOBO- ASUS P8Z77-V-LK $144.99 w/ $20 MIR (opted for this, over the P8Z77-V-PRO because i don't need the wifi/ am i correct that those are the only difference factor? and performance should be ideally the same?)
VIDEO - ASUS Radeon HD 7850 2gb GDDR5 $224.99 w/ $10 MIR
RAM - Corsair Vegeance 8gb - CMZ8GX3M2A1600C9 $37.99
SSD - Crucial M4 128gb $ 108.23 (opted for SSD for performace i only need a couple games on there at a time, and my operating system) do you recommend a HDD? there is a WD blue 1tb for $99
POWER - Corsair HX 750 $129.88
DVD - ASUS 24B1ST 24X $18.99
TOWER MID - ANTEC 900 $49.99
OS - WIN 7 HOME PREM. $97.99
FAN/SOUND/ETHERNET $0 (STOCK)
*** I LOOKED AT PARTS HIGHER UP BUT WOULD HAVE COME AT A COST EX/ CORSAIR HX750 VS AX750 OR THE MOBO P8Z77 LK VS PRO ($50 DIFFERENCE)
love some input on what i have chosen, you know my criteria and budget. i think what i have picked will do the job without sacrificing quality and performance. if you can think of anything that is worth swapping for a reasonable price increase/decrease let me know thanks.
CPU - i5 3570K $219
