Simple and small computer for light work
Last response: in Systems
September 23, 2012 2:01:01 PM
Hi,
I need a new computer that will be used for ineternet and office and this is the build Im thinking of :
Intel Core i5 3450 3,1Ghz (Ivy Bridge)
Asus P8H77-I mITX
Corsair 8GB (2x4096MB) CL9 1600Mhz VENGEANCE LP
2TB Western Digital Caviar Green
Samsung SSD Basic 830-Series 128GB
Corsair CX 430W V2 80+
Optiarc AD-7280S SATA, OEM
Im thinking of the following cases BitFenix Prodigy Svart mITX or Cooler Master Elite 120 Advanced mITX
What do you think of this? Is there somthing that I should switch?
September 23, 2012 2:10:05 PM
We would need to know what type of "work" you are doing, and what budget you are looking for.
If you are talking about using MS Office products, then your build is much more then enough.
September 23, 2012 2:56:42 PM
Yes, this will be used for internet and MS Office products. Also some simple games like flash games.
The budget is set to as cheap as possible but with high value. If we get alot more performance for the stated simple tasks then it will also be worth some money.
