Closed
Noob question Power Supplies and Graphics card Compatibility
  • Graphics Cards
  • Power Supplies
  • Compatibility
  • Graphics
  • Product
Best solution
a c 291 U Graphics card
a b ) Power supply
August 3, 2012 10:57:09 PM
Don't get that power supply shaped object only fit for acting as door holder... It's a very very very bad buy.
That graphics card does not need external connectors. It would work with just about any 300 watt+ power supply, however, buying that object is waste of money.
If you need a new power supply, get at least this one, it's ten times better:
August 3, 2012 11:04:59 PM
Fully agree with Sunius....get that Antec VP-450 for $35. One of the best budget priced power supplies available at under $40.
Dave
Score
August 3, 2012 11:13:05 PM
Best answer selected by austinedwards7.
Score
August 3, 2012 11:22:52 PM
Thanks guys I was a little uneasy about the power supply. any suggestions for the graphics card?
Score
a b ) Power supply
August 3, 2012 11:24:15 PM
The card you've chosen is very decent for $60-$75 range. If you've got higher budget, there are other options. What is your budget?
Score
August 4, 2012 4:14:10 AM
its quite low I could maybe go up to 80$
Score
a c 273 U Graphics card
a b ) Power supply
August 4, 2012 9:11:45 AM
This topic has been closed by Mousemonkey
Score
