hi
i decided to build a pc, however after doing alot of research and talking to some people i got doubleminded, as i heard you can encounter many frustrating issues blue screens etc,
so i decided to et my old tower pc with intel pentium 4 opened up and i found it very confusing , by that i mean the header connectors and power cables, and the ide drives cables were also stiff, now i was also vary about esd so i was touching the metal case evry few minutes
now heres a list of potential components i wanted to use, what do you think of these components (p.s i intend to use these high specs mainly for video editing, not gaming)
motherboard -asus sabertoth z77
processor-i7 3700k (do not plan to overclock, is it worthwhile?)
ram- corsair vengeance blue ddr3-1600mhz 4*4gb (16gb)
psu- corsair 750w
gpu-nvidia gt-640 2gb asus
case- haf cooler master 932 advanced case(mid tower)
wireless card for wifi-tplink
windows 7-oem version
ok now what do you think of these components will they work, any issues
furthermore when opening up my old case i accidently broke some plastic of the stock heatsink/fan
it was the old clip on types
can i use a corsair v8 cooler fan instead of the stock and will there be any problems, will i be able to overclock without cooling system
main thing is i dont want to fry the motherboard and waste alot of money
also i am not familiar with bios, is it complicated, and how does installing windows 7 oem work?
i would appreciate it alot if you can add/remove anything from the list to better my experience
also is 750w too much would 600 be fine?
i also was thinking of having l.e.d fans is that a bad idea?
thanks
psu- corsair 750w
thanks
