Intel i5 3570k
ASRock Z77 Extreme4
2GB EVGA GTX 670 FTW
2x4GB Corsair DDR3 Vengeance Jet Black Low Profile RAM
Corsair CMPSU-750AX PSU 750W Gold
WD 1TB Caviar Black 7200RPM 64MB Cache
Sony 24x Black SATA DVDRW Drive OEM
Cooler Master Hyper 212 EVO
NZXT Phantom 410 White
23.6" ASUS VE247H 1920x1080 2ms 50Hz-76Hz
Razer DeathAdder Respawn 3500 DPI
Logitech K120 Keyboard
Razer Goliathus Omega Control Mouse Pad Fragged
Arctic Silver 5 Thermal Compound
2M Plexus HDMI Cable
20M Cat-5e RJ45 Cable
2x SATA III 6Gbps Internal Cable
ScanFX Antistatic Wristband
2x 100 Pack 100mm x 2.5mm Cable Ties
Just decided to include everything. Will be buying on Wednesday hopefully so just want to know about any last minute changes. I want to be able to play Battlefield 3 on "Ultra" settings, with decent FPS.
Is the monitor alright, etc?
The 2 SATA cables are for the optical drive and the future SSD I'll be buying.
My budget was £1200 but I've already hit around £1250 so I don't really want to go any higher.
Is there anything you'd change?
ASRock Z77 Extreme4
