I recently built a new computer using a Corsair 750W power supply from a previous build, so it's about 4 years old. I've never had any problems with it.
New build:
i3570 with aftermarket cooler
ASROCK z77 Extreme4
Radeon 7870
16GB RAM
Intel SSD
3 other HDDs
Everything was fine for the first few weeks, then my computer started randomly restarting with no error messages, no blue screens - not under heavy load times like 3 hours into a gaming session, but during minimal load times like surfing the internet while nothing else was open. This happened maybe once a week, sometimes twice in a row, but everything seemed to be ok so I chalked it up to '*** happens.'
Last night I restarted my computer for normal reasons, and on reboot it got stuck on the mobo splash screen. After several power cycles it still wasnt getting past the mobo splash screen so I disconnected all the USB inputs and voila, it got past. So I plug the peripherals back in and everything seems ok, then after a few minutes, another random restart. Same deal, getting stuck at the mobo splash screen. During this time I got several different error codes on the mobo - 64 (CPU problem?), 4F (memory problem?), 3b (?)...nothing consistent.
Finally I unplugged the power, turned off the PSU and let it sit, then cleared the CMOS, plugged everything back in, and... boot cycle stuck at the Windows 7 splash screen. Go through this whole process again, finally loads windows but takes about 4 times as long to get past the Windows 7 splash screen as normal.
Based on my reading it seems most likely that my PSU is failing:
1) random restarts
2) trouble booting up and inconsistent errors blaming memory or CPU
3) its the only part of the build not brand new
Thoughts? I don't have a PSU tester but I'll try to get one on my way home from work.
New build:
ASROCK z77 Extreme4
Radeon 7870
16GB RAM
Intel SSD
3 other HDDs
1) random restarts
