Solved
2D vision (3 monitor) on a single gtx 680
Hey guys first time pc bulider here,
How would i go about setting up 2D surround on a gtx680? Would i plug 1 monitor into hdmi and the other two into dvi? Is there some adapter i need or somthing?
SIDE NOTE: i would like to plug all three monitors into hdmi if that is possible. I will get another gtx680 so i can run sli when i get the money. Here is the monitor(s) http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Thanks in advance guys!
Best solution
Yes.
You can use DVI male to HDMI female adapters if you want to use HDMI for all of your monitors.
Related ressources
Ask the community
