Tom's Hardware > Forum > Windows XP > Configuration & Customize > System Folder Default Settings
Forum Windows XP : Configuration & Customize - System Folder Default Settings
Archived from groups: microsoft.public.windowsxp.customize,microsoft.public.windowsxp.general,microsoft.public.windowsxp.music (More info?)
When you click on the system folder " My Music" the menu on the L hand side
should show "Music Tasks", but mine shows "Picture Tasks".
Does anyone know how to reset it.
Thanks for any advice.
Paul Woodsford
Remove NOSPAM to reply.
Sponsored Links
Paul,
I would try going to folder options and switching to Windows Classic View,
applying the settings, then switching back to "show common tasks in folders"
view and see if that fixes it.
-Jeff
"Paul Woodsford" <paul.woodsford@NO SPAMvirgin.net> wrote in message
news:urhU5iZrFHA.1724@TK2MSFTNGP14.phx.gbl...
> side should show "Music Tasks", but mine shows "Picture Tasks".
> Paul Woodsford
Reply to Anonymous
Thanks David.
The "Reset All Folders" did it.
Paul Woodsford
"David Candy" <.> wrote in message
news:uZeYLtarFHA.3852@TK2MSFTNGP15.phx.gbl...
To make all folder views the same
1.. Open a folder and select a folder view.
For help with selecting a folder view, see Change how you view items in a
folder.
2.. On the Tools menu, click Folder Options.
3.. On the View tab, click Apply to All Folders.
Note
a.. To reset all folders to the settings that were in effect when Windows
XP was installed, click Reset All Folders.
http://webdiary.smh.com.au/archive [...] 01075.html
> side
> Paul Woodsford
Reply to Anonymous
There are 1160 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
