Sign-in / Sign-up
8 Channel HD Audio On Old Speaker System
  • Sound Cards
  • Speakers
  • Audio
  • HD
  • Components
Last response: in Components
February 8, 2013 1:24:13 AM
I'm looking at buying a motherboard and nearly all of the ones that I've been considering generally have onboard 8 channel HD Audio. This obviously means 4 separate input ports (e.g. front speakers, rear speakers, central speaker, subwoofer).
The speaker system that I have at the moment is a fairly decent but old one. Consequently it only has one jack on it for traditional stereo connections.
I was wondering if I am going to loose some of the sound output and/or quality by not plugging in all four ports and if I am just how bad it will sound? I will upgrade the speakers at some point but can't afford to at the same time as upgrading most other PC hardware.
More about : channel audio speaker system
February 8, 2013 6:31:33 AM
You'll loose 6 channels of sound. Mostly a concern if you play a lot of 3d games where you want to know if something is behind you. Other than that, it'll sound fine.
February 9, 2013 12:44:55 AM
Thank you for the reply. I'll barely be playing any games whatsoever, its mainly music I'm interested in making sound decent and to a slightly lesser extent DVD's and videos (e.g. You Tube, AVI files etc).
Ok so am I right in thinking that what you are implying is that for instance, if I listen to a stereo audio track, as it's only contains 2 audio channels it won't make any difference if I plug 1 jack in or 4 jacks? If so then I think I finally get this multi-channel HD Audio thing. Whilst researching my PC build it has been the only technology I could seem to find barely any information at all about.
February 9, 2013 7:09:55 AM
The PC should know how many jacks you've connected, but check your speaker settings are set to 2.0 (don't set it for 2.1 even if you have a sub, the receiver should handle that) and it'll mix everything for stereo.
February 9, 2013 10:41:29 PM
Ok great cheers for the help.
