Closed Solved
How many watts do I need for my power supply?
My future computer setup is going to basically be this:
SSD
2x HDD (possibly 4)
2x 7970 ghz edition GPU
4x 8gb 1600 RAM
i7-3770k 3.5ghz quad core CPU
Mid-High end motherboard
2x DVD Burners
Blu-Ray Burner
USB 3.0 Card reader
LED fans
Esitimates told me I needed about 1000w, is that correct? If so are these good power supplies? which would be better?
Corsair or Cooler Master?
6 answers Last reply Best Answer
More about watts power supply
  1. A good and reliable 750W will run the entire system easily.
    Would getting one slightly more than 750w help it run cooler? Or would it just be pointless?
  3. Best answer
    Yes, a 750W psu will do, there's this one for just 95$ : http://www.newegg.com/Product/Product.aspx?Item=N82E16817182264
    Made by super flower, it's a high quality psu, see the review here :
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=266
    A higher wattage psu won't run it cooler, it's just pointless.
    Ok thanks, Neweggs estimate was like 1050 watts or something ridiculous like that, you saved my 100 bucks probably, thanks
    SSD
    2x HDD (possibly 4)
    4x 8gb 1600 RAM
    2x DVD Burners
    Blu-Ray Burner
    USB 3.0 Card reader
    LED fans
    Hi - realhardtech suggests 800w to CF 2 7970's and there's headroom built in
    to that, so amuffin & dj are correct that a 750 will run it. With the amount of
    storage devices and multiple burners, you might want to look at good quality 850w units,
    but more $$ and that capstone 750 is an excellent psu.
  6. Best answer selected by shuasgusdfal.
Power Supplies Hard Drives Components
