Archived from groups: rec.photo.digital.point+shoot (More info?)
Hi all,
I bought the named model the other day. After several hours of error free
operation, the camera started to switch off immediately after switch on.
The error persists a while and seems to go away if I leave it alone for
some time. It doesn't seem to be a power supply problem as the battery is
far from empty. I consider this a manufacturing error. I'd like to learn
whether anybody else here had the same problem with this model or the
SL300R?
"Robert Klemme" <bob.news@gmx.net> wrote in
news:2uc4p5F25mi8aU1@uni-berlin.de:
> free operation, the camera started to switch off immediately after
> switch on. The error persists a while and seems to go away if I leave
> it alone for some time. It doesn't seem to be a power supply problem
> as the battery is far from empty. I consider this a manufacturing
> error.
Return it. What is the refund/exchange policy of the merchant?
"Woodchuck Bill" <bwr607@hotmail.com> schrieb im Newsbeitrag
news:Xns95904B140DEB1bswr607h4@130.133.1.4...
> > error.
> Return it.
That's what I've done this morning. (Mailed it.)
I'll get a replacement (European consumer protection laws are in effect,
I'm in Germany; refunding is also an option).
I was mainly interested to hear whether others have had the same issue
with these models. I'm sorry if that hasn't become clear enough from my
post.
"Robert Klemme" <bob.news@gmx.net> wrote in news:2ucg2nF26rir9U1@uni-
berlin.de:
> post.
It was clear. :-) I was just making a general suggestion. Please keep in
mind that this newsgroup was created less than 24 hours ago, and it has yet
to appear on many servers. The traffic will pick up in due time.
Kibo informs me that "Robert Klemme" <bob.news@gmx.net> stated that:
>Hi all,
>far from empty.
I'm guessing that you were too impatient to try your new camera to
follow the instructions about conditioning your new battery. Many
digicams require you to charge a new battery for 24 hours (or some other
quite long period) before using it for the first time. If you failed to
do that, it'd explain why your camera *thinks* the battery is nearly
full, when it's actually flat.
Before blaming the camera, try conditioning the battery *exactly*
according to the instruction book, & see if that fixes the problem.
W
. | ,. w , "Some people are alive only because
\|/ \|/ it is illegal to kill them." Perna condita delenda est
Lionel <nop@alt.net> wrote in
news:1472o0po46qmi5eb4ckq38khpc6mesn8am@4ax.com:
He posted that he already sent it back, but this is some good advice. If he
runs into the same problem with the replacement unit, that may very well be
the problem.
Kibo informs me that Woodchuck Bill <bwr607@hotmail.com> stated that:
Damn, I hadn't seen his second post before writing my response.
Thanks. Can you tell that I've worked in tech-support? Back when I
worked at a Toshiba laptop distribution company, battery 'problems' like
this used to be one of the biggest cause of tech-support calls.
>If he
>the problem.
My bet is that they'll cycle his battery, find that the camera then
works correctly.
W
"Lionel" <nop@alt.net> schrieb im Newsbeitrag
news:84a2o0d1aadomi8bpo0j638j3rsjg6kqlc@4ax.com...
> >If he
well be
> >the problem.
> works correctly.
Although they might, because the error surfaces only from time to time, I
bet against this. Reasons:
- Battery was initally fully charged according to instructions
(fortunately only about 3 hrs required for a full load and no
24h initialization period)
- I could get the camera switched on in view mode and battery
indicator showed three out of three bars (i.e relatively close
to full).
- The problem surfaced shortly after the next full load.
For the moment I'll stick with my hypothesis that there is a mechanical
problem with the lens or a problem in the camera's control circuits until
someone shows up with a better alternative. ;-)
news:Xns9590549A97A31bswr607h4@130.133.1.4...
> berlin.de:
my
> > post.
yet
>> works correctly. >
I hope you made a point of mentioning this to them, because otherwise
it's entirely possible that they won't leave it on test for long enough
to make the fault show up, & you'll get it back with a snotty note
telling you that there's nothing wrong with it.
> I
Fair enough then. I've spent long enough in the technical sides of the
computer & electronics industries that I'm afraid I'm in the habit of
assuming that people don't follow the instructions, or even read them,
so please don't take my response personally.
Taking that into account, I'd be betting on either a bad battery spring,
or a faulty battery. (There are plenty of other possible causes, but
those would be the big ones.)
> to full).
Unfortunately, battery indicators are horribly inaccurate, especially
with L-Ions. The only way to be absolutely sure that a L-Ion battery is
holding a full charge is to discharge it almost completely, put it on a
trickle charge for a couple of days, then time how long it takes to run
flat under a measured load. NiMh cells aren't quite that bad, but not
far from it.
>Anyway, thanks for the suggestion!
No problem - Even if it wasn't useful to you, it might help convince
other people that it's a good idea to take the manual seriously.
> robert - eagerly awaiting the replacement
>PS: I let you know how the other one does.
Please do, I'd be interested to know the outcome.
W
news:u546o0luehoh72h82ve7pcn4emh89dmjlc@4ax.com...
>>> works correctly. >>
Of course. I've worked in technical service (printers, displays, PC's...)
to know how important a detailed error description is. :-)
While we're at it and nobody else listens... The ugliest case I had was a
printer with an embedded writer for magnetic stripes on savings books. The
writer kept moving back and forth even without a book in there. I changed
every part of that bastard but in the end it turned out that they had two
power circuits there, the printer was alone on his circuit and that was the
one with small short power outages. So the damn thing was perfectly ok, but
it did a reset once in a while because it got powered down and up so fast
you couldn't notice. Superfluous to mention that it took me quite some time
to discover that...
>> I
No offense taken. I know that I'm a bit old fashioned about reading
manuals. :-)
Btw: interestingly enough this camera comes only with a quick start manual
(with all the details about battery charging and the basics of taking
pictures) and another lightweight manual with a bit more descriptions but
not really thorough. For example: this camera features "mode lock" which is
supposed to be described in a table I couldn't make much sense of yet. I
seems to have to do with keeping certain settings after switching off, but
whether "lock" or "unlock" keeps the settings wasn't totally clear. Also, I
couldn't match the manual with the camera's behavior. I'll take a second
attempt at uncovering this mystery once I get the replacement...
>> to full).
> with L-Ions.
Good to know that. I would not have expected exact measurements but a
certain degree of accuracy... I'll keep an eye on it.
> far from it.
Hm, but then you only know the curremt capacity of the battery, i.e., you
can detect whether the actual capacity matches the nominal capacity. And
you have an upper bound of the charging time for full load. :-)
Yeah. Folks, listen to what he says: RTFM! :-)
Me too. :-) I guess I'll have to wait until Wednesday or even later. *sigh*
Good to know that my Powershot G5 still works like a breeze. :-)
I have SL300R since May. No such problem. Only problem is when memory card
is almost full, then sometime block. My card is 128 MB. Recommend larger
High Speed card to take advantage of 640x480 30fps video and 3.5 pictures
per second fast shooting until memory card is full.
Regards
Dragan
"Robert Klemme" <bob.news@gmx.net> wrote in message
news:2ucg2nF26rir9U1@uni-berlin.de...
> > > error.
> > Return it.
> post.
> Thx anyway!
> Kind regards
> robert
"Vucko" <dr_vucko@hotmail.com> schrieb im Newsbeitrag
news:2ui5ppF28jthpU1@uni-berlin.de...
Thanks for the feedback!
Well, guess what: that's the exact reason why I got me a SanDisk Ultra II
512MB card. :-) Good to know, that I picked the right one. Thanks for that
reassurement!
"Robert Klemme" <bob.news@gmx.net> schrieb im Newsbeitrag
news:2ueen3F294l8dU1@uni-berlin.de...
> > berlin.de:
issue
from
> my
> > > post.
in
has
> yet
> Yeah, true.
> > Good luck with your replacement camera!
> Thanks a lot!
I now have the replacement for a week. No problems any more. It's a
really cute little cam. For me it's the ideal carry everywhere cam.
>> berlin.de:
> my
>> > post.
> yet
> Yeah, true.
So now I have the replacement for a while and it does not show any sign
of strange behavior like the other one. So all is well. :-))
