How will a GTX 460 work with my system?
How will a GTX 460 1gb work with my phenom II X3 720 cpu 2.6 ghz? Will there be a bottleneck?
More about : gtx 460 work system
Related ressources
- Cannot get Evga GTX460 SE to work on my system - Forum
- GTX460 work with Core 2 duo set-up? - Forum
- New GTX 460 wont work - Forum
- Will my system bottleneck GTX 460 768mb? - Forum
- GTX 460 in System will POST, but Hangs - Forum
shamsmu said:
personal experience, blue screen of death got me after I tried unlocking mine about a year ago.That one depends on the motherboard and in which condition isthe 4th core. If its badly damaged like yours then maybe. On the moherboard part its that it can't restore the settings to default. Though i never had any isues like that. When i first time overclocked i set the bad voltage and after applying the settings it restarted a couple of times and asked to press F2 to restore settings to default or delete to go into the BIOS menu and fix it manualy. You know if a 40$ motherboard has this then i'm sure your rich guy's motherboard has it hehehe
Depending on your resolution and game, that CPU will not bottleneck that gfx card.
If you're running at fullHD on metro 2033, yes, but if you're running starcraft at 1280x1024 then hell no.
I would attempt an unlock, I have a 960t (6x core, locked to a 4x core) and I successfully unlocked all 6 cores and now running at 4ghz! So well worth it, you won't know if you don't try!
What is your motherboard?
teh_gerbil said:
Depending on your resolution and game, that CPU will not bottleneck that gfx card.If you're running at fullHD on metro 2033, yes, but if you're running starcraft at 1280x1024 then hell no.
Mine is an ASUS board idk the model, need to check out system info... Anyways it has ASUS core unlock feature but i'm saving for a new motherboard. A gigabyte GA 970A UD3. PSU is an antec HCG 620W. And i just put in the athlon II 445 and i successfully unlocked the 4th core and i locked it and now i'm gonna try unlocking the phenom but i can't see the difference in speed between the phenom II X3 and athlon II X3
You won't, most applications aren't too receptive to anything over 2 cores at 2-3ghz, you will notice it when you press your system, like gaming, or video editing.
I have a GA 970a d3, LOVE IT. it unlocked and overclocked like a dream, as I said 960 - 6x cores @ 4ghz (got as high as 4.2) noo worries. Full voltage control, and dual bios means even if you sooo bad as to root your bios, you've got the backup. Great for OC'ing to extremes.
teh_gerbil said:
You won't, most applications aren't too receptive to anything over 2 cores at 2-3ghz, you will notice it when you press your system, like gaming, or video editing.I have a GA 970a d3, LOVE IT. it unlocked and overclocked like a dream, as I said 960 - 6x cores @ 4ghz (got as high as 4.2) noo worries. Full voltage control, and dual bios means even if you sooo bad as to root your bios, you've got the backup. Great for OC'ing to extremes.
Well your board doesn't have any cooling on the VRM's so i would be carefull if i was you. the GA 970A UD3 is the same as the D3 but it has cooling on the VRM's
Yip, unfortunately can only pull 2.4ghz on the NB i daresay cause of that. I have a hyper 212 evo, with a 10cm case fan, and 10cm psu fan all in optimal position to cool the VRM's. debating rangi'ing up some heatfinks to put on them loosely, but at this stage, if my CPU's very comfortable at 4ghz, I'm happy.
I wish they had the ud3, but they didn't sadly. I do like the other features, like the usb 3.0, (as I said) dual bios and easy unlock features the 970 affords.
verbalizer said:
not a fan of the 970 chipset, only one motherboard with the 970 chippy runs x8/x8 all others are x16/x4.SLi minimum requirements are x8/x8, only CF-X allows for x16/x4.
so by that fact alone I went with the 990XA and then 990FX chipset.
990FX = x16/x16 and that's a win.
I don't really care about crossfire or SLI because i'm never gonna do it in a few reasons. Dual gpu setups sometimes cause problems in games and its expensive and i don't eve like how it looks.
teh_gerbil said:
Yip, unfortunately can only pull 2.4ghz on the NB i daresay cause of that. I have a hyper 212 evo, with a 10cm case fan, and 10cm psu fan all in optimal position to cool the VRM's. debating rangi'ing up some heatfinks to put on them loosely, but at this stage, if my CPU's very comfortable at 4ghz, I'm happy. I wish they had the ud3, but they didn't sadly. I do like the other features, like the usb 3.0, (as I said) dual bios and easy unlock features the 970 affords.
Hehe. See i don't have any sort of case fans, i'm so poor i have to save every penny for the new motherboard, no money for aftermarket coolers or case fans. btw when idle my CPU cooler sounds like a hair dryer but the temps are ok, 28 degrees but the noise it makes is annoying, when gaming... uhm it probably sounds like an electric drill
Lazar_99 said:
I don't really care about crossfire or SLI because i'm never gonna do it in a few reasons. Dual gpu setups sometimes cause problems in games and its expensive and i don't eve like how it looks.your personal opinion...
I never have had a problem with dual card set-up.
anyways the comment wasn't about that, it was about the weaker 970 chipset.
things are only as expensive in ratio wise to your available funds.
and depending on model GPU's it looks cool.
verbalizer said:
your personal opinion...I never have had a problem with dual card set-up.
Yeah well, i've read a lot of stuff about people have problems with lag in games due to SLI or CF. I'm not gonna risk it since i always have the worst of luck its probably gonna show me a BSOD when i atempt SLI or CF. Btw its already logical that the 990 chipset is better than the 970 but i'm not that crazy to spend more than 100$ on a board since i won't OC, just try to unlock the 4th core nothing else. But i can't see why some of you recommend a high end board to those who won't OC or any of tat stuff.
Lazar_99 said:
Yeah well, i've read a lot of stuff about people have problems with lag in games due to SLI or CF. I'm not gonna risk it since i always have the worst of luck its probably gonna show me a BSOD when i atempt SLI or CF. Btw its already logical that the 990 chipset is better than the 970 but i'm not that crazy to spend more than 100$ on a board since i won't OC, just try to unlock the 4th core nothing else. But i can't see why some of you recommend a high end board to those who won't OC or any of tat stuff.what you hear and what I see is two different things, with enough CPU strength you won't have issues with dual set-ups.
have you heard or read that.? didn't think so..
your lack of confidence is on you, don't take it out trying to go back and forth with me..
and I wasn't referring you to get a 990 chippy, you took it the wrong way.
i only stated the obvious and why I like the 990 chippy better.
and now since you took things the wrong way you try to make me feel bad because I have deeper pockets and better units.
sorry bro not happening.
Phenom II X3 720 is 2.8GHz and not 2.6GHz BTW..
verbalizer said:
what you hear and what I see is two different things, with enough CPU strength you won't have issues with dual set-ups.have you heard or read that.? didn't think so..
My mistake on the SLI, sorry. I don't usually read stuff that have anything to do with SLI or CF because i don't care about something i don't like. And i haven't said that you recommended "ME" a 990 chipset. I meant that some of you guys (not refering to you so don't say i was talking about you) recommend high end boards for users that don't want to overclock or have dual or more GPU setups. Don't they take into account that some people can't afford that stuff or some of them (like me) don't want to buy boards with features they don't need. I think you're that guy who said the MSI 870S C45 FX is bad xD Well technically it is bad if you're an overclocker
Well i don't mind people having deep pockets if they know how to use them like not spending money on useless stuff or if they don't show how rude they are when someone who doesn't have money buys for example a GTX 460 mid range and they come and say that its outdated and that they should upgrade to GTX 580. verbalizer said:
after our earlier discussion...
the GA-970-UD3 is cool.I had the GA-990FX-UD3 myself.
what model Athlon II are you speaking of, I hope it's at least a quad..
because if it's a triple or even a dual core then I'd keep the X3 720 instead.
No matter. Its an X3 but after i buy the motherboard i'm starting to save up for a PII X4 965 BE
Related ressources:
- ForumGTX 460 SLI System -
- ForumWould a Gtx460 work with my system ?
- ForumRadeon HD 7660D discrete MSI gtx460 hawk?
- ForumGTX 460 in System will POST, but Hangs Before IRQ List
- ForumHow to overclock a GTX 460 ?
- ForumHow to Powering GTX 460 in SLI
- ForumHow much extra power does OCing 2 GTX 460 's take?
- ForumHow much power do I need for Phenom 955 & 460 gtx ?
- ForumAsus gtx560ti directcuII-broken
- ForumHD 7970 or GTX 680?
- ForumNeed some help with the new card i bought.
- ForumGeForce GTX 570 (Fermi) 1280MB or Radeon HD 7850 2GB
- ForumNeed help with my new graphics card.
- Forum[Solved] How do I toggle Radeon drivers?
- Forum[Solved] GeForce GTX 560 Ti (Fermi) 2GB or Radeon HD 7850 2GB
- More resources
