kboykool
12
I have had a CL Live! Platinum 5.1 since January. It won't even install under Windows NT 4.0 with SP6--the installation software always hangs. I have tried everything and can't seem to get it to work. CL support is a joke and I'm ready to junk the card. What is the best sound card out there that is fully compatible with NT? Thanks.
Kenny
blah
2,694
heh, that is interesting, but anyway, the only thing i can say is that i am still using MX300 since Win95 and NT4 it went through 98, 98SE, ME, NT4, 2k, XP... works everywhere, also i have Ensoniq, which is SB64-128 card, works well everywhere too... have fun.
it's my life, don't tell me what to do with it...
blah
2,694
yeah, try to update driver through the Device Manager, dont install it straight from CD, just point to the folder where NT drivers are, should work without a problem that way...
kboykool
12
Or should I wait for nForce to come out and just replace my MB? It supposedly boasts built-in audio that will rival the Platinum 5.1.
Kenny
