Sign-in / Sign-up
Solved
What power supply do I need?
  • Power Supplies
  • Components
Last response: in Components
February 8, 2013 6:32:30 PM
Hello there,
I'm a short-time reader, first-time writer. I've been buying components for my PC for a couple of months and the stock PSU that came with my case isn't very good. Ergo, in order to run the graphics card I am getting, I will need to upgrade my power supply. I was looking at the Antec Earthwatts 500W PSU. The store manager at Wintronics tells me that I need the Antec Earthwatts 750W PSU.
Here are the links:
500W PSU- http://wintroniccomputers.com/323-4334/power-supplies/a...
750W PSU- http://wintroniccomputers.com/323-4337/power-supplies/a...
Now here are the specs for my PC.
CPU: FX-4100
MOBO: M5A78L-MLX PLUS
GPU: Sapphire 7850 2GB
RAM: 2x4GB RAM
HDD: Seagate 500GB SATA
Now then, the question is: do I really need the 750W PSU? My MOBO is holding all the RAM it can handle. It only has one PCI-E 2.0 slot that will be taken up by the 7850, so it's not like I need the extra 6-pin and 8-pin power cords. Both of the power supplies are 80PLUS Certified. They both have active PFC. So is the store manager trying to squeeze me for more cash?
More about : power supply
a c 1663 ) Power supply
February 8, 2013 6:44:02 PM
For a system using a single reference design Radeon HD 7850 graphics card AMD specifies a minimum of a 500 Watt or greater system power supply. The power supply should also have a maximum combined +12 Volt continuous current rating of 27 Amps or greater and have at least one 6-pin PCI Express supplementary power connector. Some of the non-reference design Radeon HD 7850 graphics cards require at least two 6-pin PCI Express supplementary power connectors.
There is a SAPPHIRE HD 7850 2GB GDDR5 model where Sapphire states that 2X75 Watt 6-pin PCI Express power connector is required.
The Antec EarthWatts Series 500 Watt (EA-500), with its maximum combined +12 Volt continuous current rating of 34 Amps and with two 6-pin PCI Express supplementary power connectors, is more than sufficient to power your system configuration with a single Radeon HD 7850 graphics card.
m
l
Best solution
a b ) Power supply
February 8, 2013 6:47:28 PM
You absolutely do NOT need a 750W power supply. The 500W is more than sufficient to run the parts you've listed.
He's trying to squeeze you.
February 8, 2013 6:48:02 PM
The specs say 2x75W power cords are required for Crossfire. Only one 6-pin is required for the use of one card.
m
l
February 8, 2013 6:49:00 PM
Thank you for your response. I kind of felt like someone was tickling my udders.
m
l
February 8, 2013 6:53:10 PM
Best answer selected by meetreez.
m
l
February 8, 2013 6:54:48 PM
You never specified exactly which model you have. Sapphire makes more than one model of SAPPHIRE HD 7850 2GB GDDR5 card. There are some models that require one 6-pin PCI Express supplementary power connector and others that require two 6-pin PCI Express supplementary power connectors.
m
l
February 8, 2013 6:55:00 PM
Thank you for helping me out. I wish I could select multiple "Best Answers" as you have both helped out so much. :)
m
l
