Approximate Purchase Date: this october-november
Budget Range: (1000$-1200$) No shipping
System Usage from Most to Least Important: (3d modeling,texturing rendering,Post production,Architectural Visualization some small time gaming RTS/FPS gaming)
Already have a PS3 so no serious PC gaming mainly work and a bit RTS gaming
Are you buying a monitor: No
Parts NOT Required: Mouse,KEyboard,HDD,Speakers,DVD-rw
Parts to Upgrade: Need a config for a Sandy Bridge and IVy Bridge build suggestion seperately And ill choose the one of them depending upon
better performance to Price value/future Proof and reliability
Things that wont need to be changed in these both builds would be RAM,Chasis,PSU,GPU you can in case there are any compatibility issues with certain components
i5-2500k http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
i7-2600k http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070&Tpk=i7%202600k
i7-2700k http://www.newegg.com/Product/Product.aspx?Item=N82E16819115095&Tpk=i7%202700k
i5-3570k http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
i7-3770k http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
i7-3820 ?? if possible in this build performance and price wise
Motherboard: Not much Idea coz cant tell which one is better than the other and why although would go for asus/msi/gigabyte/evga
My prefrence would be the latest and chipset based mobo which really have good perfrmance per value. the one'z I have in my mind are
Asus Sabertooth Msi military class models Gigabyte ud3/ud5 as they win recomended HW of the year and EVGA I dont why I like it but always look forward to it the most than the other brands. Would to see if u guyz have have some suggestions for this.
Can I have suggestions for the brands I have listed which will be best in budget or otherwise good for the build
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821 sabertooth z77
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130645 msi z77 gd 45
RAM: 8GB corsair vengeance
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
8GB kingston hyper x
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104239
Chasis:
I am looking for looks performance as well as bigger in size. I like the haf CM cases and the corsair (My prefrence) cases as well as would like the case to be big if possible within if u guyz have better suggestions.
CoolerMaster haf 912 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233 ( didnt like thier interiors corsair much better)
haf 922 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Corsair 500r http://www.newegg.com/Product/Product.aspx?Item=N82E16811139009
650d http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006&Tpk=corsair%20650d
Open to Suggestion in Both these brands if there any other good high end cases if they could fit in budget and from any other brand if its better in perfromance/looks and reliabilty and availability ill go for it.
PSU: Corsair 650w
GPU: THis is a tough one I would like the one that would handle very high poly viewports well and have performance rendering and otherwise
Quadro 2000
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133353
Firepro v4900
http://www.newegg.com/Product/Product.aspx?Item=N82E16814195109
Firepro v5900
http://www.newegg.com/Product/Product.aspx?Item=N82E16814195106
I heard that the latest geforce cards also perform veryy good in Professional CADand other animation softwares as well and someone suggested me these
MSI 560TI twin frozer3 hawk
http://www.msi.com/product/vga/N560GTX-Ti-Hawk.html
MSi 660ti Power edition/OVerclocked edition/Twin frozer2
http://www.msi.com/product/vga/N660Ti-PE-2GD5-OC.html
Palit 670 jetstream
http://www.palit.biz/palit/vgapro.php?id=1975
SSD: YEs if possible with budget ocz or intel etc. otherwise you could go out of budget with this one ill add it later after some time.
Do you need to buy OS: No
Preferred Website(s) for Parts: (e.g.: newegg.com, amazon etc -- to show selection & pricing) Need links to just as a refrence to these sites for the parts probably will buy from a local vendor just looking for the best build in this budget(approx)
Overclocking: Maybe later in the future
SLI or Crossfire: No
Additional Comments: ( Need to have a Good GPU that can handle very heavy viewports could be geforce if possible to firepro or nvidia(my prefrence)
Softwares Using Maya/3DS Max/Zbrush/ADobe designer pack/and would be using Fusion and Nuke in Future
And Most Importantly, Why Are You Upgrading: (Upgrading from my old PC which was a c2d with a 9400gt gpu and 2gb ram and yes its broken and out of warranty and its motherboard usb's dont work anymore and is now veryyy slow for my work and hangs a lot)
Will choose Sandy Bridge or Ivy Bridge build depending upon which gives best performance to price value and is more future proof and the which will be faster .
Please suggest a good build and narrow it down for me MAINLY looking for the highest performing build in this budget SB or IB .
Chasis:
PSU: Corsair 650w
Quadro 2000
Firepro v4900
Firepro v5900
Palit 670 jetstream
