Archived from groups: microsoft.public.windowsxp.customize (More info?)
When I right click on start key, go to properties, click start menu, click
customize, then click on advanced, I have no options. It opens up to a
windows explorer type menu. I can't click on items to customize how my start
menu behaves because there aren't any there. Help!!
Type in Start Run
regsvr32 /i shell32
http://webdiary.smh.com.au/archive [...] 01075.html =================================================
"Phoebe" <Phoebe@discussions.microsoft.com> wrote in message news:239705A0-4CCE-465B-BA3A-78ED84472984@microsoft.com...
That didn't fix it. I still have the same problem. Any suggestions?
"David Candy" wrote:
> Type in Start Run
> regsvr32 /i shell32
> http://webdiary.smh.com.au/archive [...] 01075.html > =================================================
news:9EEC9762-178A-4D43-BFEB-6BF704F51F32@microsoft.com...
>> Type in Start Run
>> regsvr32 /i shell32
>> http://webdiary.smh.com.au/archive [...] 01075.html >> =================================================
>> > click
>> > start
I am on a network and have recently gotten a new computer. My old computer
was on the same network and I was able to customize my start menu so that
only my most recently used programs were displayed. Ever since I got this
computer I can't customize my start menu the way I could before. How do I
run that command as Admin user?
"Ramesh, MS-MVP" wrote:
> Make sure that you're running that command as Admin (or equivalent) user
> account. Register this module as well:
> regsvr32 /i browseui.dll
> Restart.
> Ramesh, Microsoft MVP
> Windows XP Shell/User
> http://windowsxp.mvps.org >
> >> Type in Start Run
> >> regsvr32 /i shell32
> >> http://webdiary.smh.com.au/archive [...] 01075.html > >> =================================================
> >> > click
> >> > start
news:B5B67CCA-5FE0-4D5A-82E6-30E188325144@microsoft.com...
> this
>> Restart.
>> http://windowsxp.mvps.org >>
>> >> Type in Start Run
>> >> regsvr32 /i shell32
>> >> http://webdiary.smh.com.au/archive [...] 01075.html >> >> =================================================
>> >> > click
>> >> > to a
>> >> > my
>> >> > start
I found my problem. Right click on start, properties, start menu, customize
then check the personalized menus box. That is supposed to hide any programs
I haven't used recently. That box is checked but it doesn't change anything.
Will running regsvr32 commands fix that problem or is there a patch I need
to download?
> > this
> >> Restart.
> >> http://windowsxp.mvps.org > >>
> >> >> Type in Start Run
> >> >> regsvr32 /i shell32
> >> >> http://webdiary.smh.com.au/archive [...] 01075.html > >> >> =================================================
> >> >> > click
> >> >> > to a
> >> >> > my
> >> >> > start
then click on use personalized menus. Checking this box should hide programs
I haven't used recently used and it doesn't. Is there a patch I need to
download or will running regsvr32 commands fix that problem?
> >> How do I run that command as Admin user?
> If the system is connected to a domain, you need to talk to the network
> admin, or have them run the regsvr32 commands in your system..
> > this
> >> Restart.
> >> >> Type in Start Run
> >> >> regsvr32 /i shell32
> >> >> > click
> >> >> > to a
> >> >> > my
> >> >> > start
