$1100 Build need some help
Hello I'm about to build a computer for my dad and its been a while since I built one and havent kept up on all the new parts, so looking for a little info.
Use of computer playing wow on Max settings 27" 1920-1080p monitor. No OCing
Mother board and os - http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1032600
GPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16814127697
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139031
HDD - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
CD/dvd - http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Ram - I have already 8gigs
Need a case still idk what to pick need somthing to stay cool and has dust filters cause they keep there house hot.
Any feed back would be great thanks.
7 answers Last reply
More about 1100 build help
  1. That setup will handle wow. Just make sure the ram you already have is decent (DDR3). I would just look at the current gen i5 3570k, but its not really necessary if the money isnt there for it. Cases vary a lot, depending on the look you want. If theres no window then you wont need as good cable management for asthetics, just for airflow. Any decent case you are thinking about will probably have a video on youtube of someone going over its features which is very helpful. Work out your budget for the case to narrow it down, also if you can get an SSD boot drive you will be up and running a lot faster.
  2. If you don't plan on overclocking then go with this.
    cpu - i5 3570 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115233
    mobo - asrock h77m http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303
    case - corsair 400r http://www.newegg.com/Product/Product.aspx?Item=N82E16811139008
    os - windows 7 http://www.amazon.com/Windows-Premium-64bit-System-Builder/dp/B004Q0PT3I/ref=sr_1_1?ie=UTF8&qid=1348629891&sr=8-1&keywords=windows+7
    That will work better than what you had and is cheaper. Don't need a k cpu if you're not overclocking.
  3. If you're not overclocking, no need for a -K processor. Go with this i5-3570 instead.
    That PSU is way too expensive. This Antec 650W is a better buy.
    If you plan on playing Borderlands 2 (it's an awesome game, you should), your GPU choice is good. If not, maybe go with a hd 7950 instead. It should be a little bit faster in most games.
    I would try to squeeze a SSD into your budget, even a 60GB one. 60GB is only enough for OS, apps, and about 1 large game, but it makes your system seem much more responsive.
  4. Really if you're not overclocking a good 500w psu is more than enough power. This is a good psu and at 550w its a better fit for your build xfx pro550w http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
    You want to make sure that RAM is 1.5v or else it can mess up the controller on these 1155 boards. You don't need a GTX 660 ti either to max out WOW on high settings.
    These benchmarks were done with a GTX 660 at stock settings. That Gigabyte GTX 660 in this build is factory over clocked to the max.
    Just ad a storage drive to this build.
    http://www.amazon.com/Antec-Three-Hundred-Two-Gaming/dp/B006TVQTHW/ref=sr_1_5?s=pc&ie=UTF8&qid=1348630543&sr=1-5 $59.99 & this item ships for FREE with Super Saver Shipping
    Antec Three Hundred Two Gaming Case, Black front 3.0 USB
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030 $54.99 $10 off w/ promo code CollegeSave10, limited offer
    Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157304 $84.99 FREE SHIPPING
    ASRock Z75 Pro3 LGA 1155 Intel Z75 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1053748 $206.98 save: $10.00
    Intel Core i5-3470 Ivy Bridge 3.2GHz (3.6GHz Turbo Boost) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 2500 BX80637i53470
    SAMSUNG 22X DVD Burner SATA Model SH-222BB/BEBE - OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186 $38.99 FREE SHIPPING
    CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model CML8GX3M2A1600C9
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820171646 $94.99 FREE SHIPPING
    SanDisk SDSSDP-128G-G25 2.5" 128GB SATA III Internal Solid State Drive (SSD)
    http://www.amazon.com/Gigabyte-PCI-Express-Displayport-Graphics-GV-N660OC-2GD/dp/B00942TK8I/ref=sr_1_2?s=pc&ie=UTF8&qid=1348585061&sr=1-2&keywords=gigabyte+gtx+660 $229.99 & this item ships for FREE with Super Saver Shipping
    Gigabyte GeForce GTX 660 OC 2GB GDDR5 PCI-Express 3.0 DVI-I/DVI-D/HDMI/Displayport SLI Ready Graphics Card GV-N660OC-2GD
    Core Clock 1032MHz
    Boost Clock 1111MHz
    http://www.amazon.com/Windows-Premium-64bit-System-Builder/dp/B004Q0PT3I/ref=pd_bxgy_pc_text_y $90.95 & this item ships for FREE with Super Saver Shipping
    Windows 7 Home Premium SP1 64bit (Full) System Builder DVD 1 Pack
    Total: $861.87 *not including shipping & promo code
    http://www.amazon.com/Antec-Tricool-Speed-120mm-Case/dp/B00314W992/ref=sr_1_2?s=pc&ie=UTF8&qid=1348585896&sr=1-2&keywords=Case%2BFan <---- additional case fans for that Antec case up above.
  6. This board down below was just recently released and it allows for SLI. That card down below is factory over clocked and will obviously get more FPS in WOW for the same price as that MSI card you have up above. Windows 7 64bit OEM is going for $90 + free shipping @ amazon.
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1066112 $306.98 save: $13.00
    ASRock Z77 Extreme3 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    http://www.amazon.com/GIGABYTE-WINDFORCE-PCI-Express-Graphics-GV-N66TOC-2GD/dp/B008UG2W20/ref=sr_1_1?s=pc&ie=UTF8&qid=1348532550&sr=1-1&keywords=gigabyte+gtx+660+ti $299.99 & this item ships for FREE with Super Saver Shipping
    GIGABYTE GeForce GTX 660 Ti WINDFORCE 2X OC Edition 2048MB GDDR5 PCI-Express 3.0 2x DVI / HDMI / DP SLI Ready Graphics Card Graphics Cards GV-N66TOC-2GD
    Core Clock: 1032MHz
    Boost Clock: 1111MHz
Build Computer Systems
