First time system build
Hey all,
I am looking for some advice on a system that I am building the specs are as follows and I am unsure what power supply I should use for this build. Some advice would help a great deal
case: Thermaltake Commander MS-III case
MoBo: ASRock z77 pro4-m intel LGA1155
CPU: i5 3570k-lga-1155
ram:Gskill DDR3 8Gb PC-10800/1600 Ares
HDD 1: intel 330 120Gb SSD
HDD 2: Seagate Barracuda 1TB
GPU: Nvidea GTX-670oc 2Gb
CPU Fan: cooler Master Hyper TX3 Evo
As for the power supply I was looking at something like the Antec HCG 700W but I was told that the 520W would be enough but gigabyte recommend 550W to run that card so I'm not sure
2 answers Last reply
More about first time system build
  1. 500W is more than enough.
  2. Thanks :D :bounce:
Homebuilt Systems
