Hi there,
I'm really sick of my old PC and it's incapability to run good games. I'm not sure just how old it is but the specs, as far as I know, are pretty terrible. It is in no way a gaming rig. http://www.ekowcomputers.co.uk/packard-bell-imedia-d2525uk-desktop-pc---black-24-p.asp Is my PC with all it's components - This is what mine is currently, as it has never been upgraded before.
Upgrades I was hoping to get for this:
Processor - http://www.amazon.co.uk/AMD-Bulldozer-FX-4100-Socket-Processor/dp/B005UBNL0A/ref=sr_1_6?ie=UTF8&qid=1359794385&sr=8-6
Graphics Card - http://www.amazon.co.uk/Sapphire-11202-13-20G-Graphics-Express-Technology/dp/B0096WIFU0/ref=sr_1_11?s=computers&ie=UTF8&qid=1359794590&sr=1-11
RAM - http://www.amazon.co.uk/Corsair-CMSO8GX3M1A1333C9-Module-Unbuffered-SODIMM/dp/B005T63BEM/ref=sr_1_19?s=computers&ie=UTF8&qid=1360430074&sr=1-19
PSU - http://www.amazon.co.uk/Corsair-Builder-Series-Bronze-Supply/dp/B009RMP44O/ref=sr_1_8?s=computers&ie=UTF8&qid=1360430599&sr=1-8
Motherboard - http://www.amazon.co.uk/GIGABYTE-GA-78LMT-S2P-Motherboard-SB710-Micro/dp/B007EZHLEC/ref=sr_1_2?s=computers&ie=UTF8&qid=1360431065&sr=1-2
Please recommend a case if my current one won't do the job!
Do I need to replace the disc and hard drives?
- Will the components fit in the current computer's case?
- Will air circulation be fine in this current case?
- Are the components compatible with each other? So hopefully you can see my nooby dilemma
Is there:
- Anything I need to upgrade, change, or anything I have missed? The cheaper the better, so generally any cheaper items recommended would be amazing!
- Anything I don't need to upgrade or change?
Bearing in mind that I'm looking to play games like Skyrim on around Mid to High graphics - is this achievable with these specs?
Thanks so much to all who help me answer this!
Is there:
