Hello,
I have recently bought new AMD FirePro V4800 gfx card. and i have two main issues with it.
First let me describe my configuration:
i am having Advantech PC with "PCE-5126QG2-00A1E" motherboard,
& 3 LG Make 22" LCD monitors with only VGA port available on it.
now that V4800 only has two Display port and one DVI port, i bought two Display port to VGA converter and one DVI to VGA converter in order to connect three monitors.
but when i connect the system and install the driver, it only detects two monitors. the third screen remains blank. talking to the vendor i learnt that if i change "Display port to VGA converter" to "Display port to 2-VGA output converter" it will detect the third monitor, that is still to be tried, but if that is true then what is the point for having three port on gfx card? but anyway that is the first problem, is there any way to make it detect third monitor without buying extra converter?
Second problem is that, both my monitors are able to go upto 1280x1020 resolution only even they are capable of taking higher resolution e.g. 1920x1080, if i set higher resolution than 1280x1020 than it says "Out of range", i have tested monitors independently (with other PC) to take 1920x1080 resolution, then why it is limited to such lower resolution with v4800?
when i look at the confusing specs on AMD website, it seems V4800 is able to support 3 monitors without having any resolution problem. can anyone please let me know what am i doing wrong here?
