New PC build help
Ok first I gotta be honest im not really good with pc hardware's all I do is play with my pc its my kind of having fun but anyway here's my build I found this on a digital storm build and i copied it and changed some of the parts
CASE-Cooler Master HAF 912 Mid Tower and an NZXT 140mm case
LG Super Speed USB 24X DVD / 48X CD External Drive Reader
GPU-ASUS HD7770-DC-1GD5-​V2 AMD Radeon HD 7770 VGA 1 GB GDDR5
MEMORY-Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
PSU-Product:Corsair Gaming Series 800-Watt
RAM:Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1866 MHz (PC3 15000) 240-Pin DDR3 SDRAM
MOTHERBOARD-ASUS M5A97 R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
CPU-AMD FX-8150 FX 8-Core Black Edition Processor Socket AM3+
so tell me if something is wrong or not compatible to each other it will really help and thanks in advance :'>
and also PLS TELL ME IF THEY WILL WORK TOGETHER AND WILL WORK WITHOUT NO PROBLEM
and anyway should i get a "Corsair Hydro Series H80 High Performance Liquid CPU Cooler" and I think im gonna overclock if needed.....
So.. yeah :D
4 answers Last reply
More about build help
  1. the build is bad. much better
    http://pcpartpicker.com/p/iHiC
  2. looks fine and yes will work toghether. Just double check that the ram is certified for that motherboard (on the motherboard manufacturer website)
    oh and unless you're planning to CF the 7770 a 800W PSU is overkill. You need 600W at most, probably less.
  3. even with a 7770 crossfire, it wouldnt draw more than 150w
    I dont really know if its certified or not and I cant see it on the manufacturers website can you pls look it for me :) if you do that I'll select you as the best answer but anyway here's the amazon link http://www.amazon.com/Corsair-Vengeance-240-Pin-platforms-CMZ8GX3M2A1866C9/dp/B004CRSM52/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=3C8EFKTASO118&coliid=I1B0XXDST0ZSQB
New Build Systems
