Best CPU Cooler for AM3+/Rosewill Mid ATX case?
  • CPUs
  • Cases
  • Fan
  • Cooling
  • Product
Last response: in CPUs
February 10, 2013 9:50:27 PM
Hey , so I have an AM3+ AMD-FX 832 at stock speeds, but I plan to overclock a bit or a lot. I have a Rosewi Mid ATX Gaming Case (Challenger) with a rear fan (120mm) and top fan(140mm) and some front fan that doesn't matter. So what I'm asking is:
What's the best CPU cooler (water cooler preferably, since I want to try them out) would be best AND fit in my case? Also, which fans do I remove? Also, the price range would be anywhere to $100 or less. No more. Thanks guys,
-Elijah
More about : cpu cooler am3 rosewill mid atx case
a c 136 à CPUs
February 10, 2013 10:09:53 PM
at that price u will only get a closed looped water cooler. its still using air to cool the cpu. id recommand this as ur case isnt that great for water cooling setups and the dh-14 can do just as good as the h100i water cooler.
80$ or if ur on a budget and want somethign smaller
same cooler i got myself for overclocking my 8350 ;)
m
l
February 10, 2013 10:14:13 PM
Is the one you have pretty quiet even under load? My stock fan doesn't get too loud under load and I don't want to increase the noise with one of these coolers.
m
l
