Help Diagnosing Hardware Issue
  • Homebuilt
  • Hardware Issue
  • Systems
Last response: in Systems
September 28, 2012 4:36:43 AM
Hi, I just finished building my first homebuilt and I'm running into hardware problems and so fare I haven't been able to find help anywhere.
I've been able to boot up, install Windows 7 Ultimate and use the system, however after a day or so the system becomes unstable. First, the computer begins to stall whenever I access a hard drive. When I try to reboot I get hangs during POST.
If it boots (and sometimes it doesn't ever) windows won't be able to see the bluetooth adapter on my motherboard. Sometimes I won't be able to access my SATA devices aside from the boot disk as well.
I've previously looked for help on Reddit/buildapc (did not receive a response) but it does have a lot more info about my build, symptoms, and things I've tried to fix/diagnose the problem.
As I said, this is my first build so I'm not sure what I can do. Any help would mean a ton to me.
Reddit post:
http://www.reddit.com/r/buildapc/comments/10fvpg/troubl...
More about : diagnosing hardware issue
September 29, 2012 12:57:01 AM
Check to make sure your motherboards bios version is up to date. Easy to find out from the manufactures site. Other than that try reinstalling windows.
m
l
