Is this power supply sufficient for this build? I just want to make sure so that I won't be changing my psu after a couple of months. Thanks for the future feedbacks and comments.
Processor, Intel Core i5 3570 6M Cache, 3.40 GHz (Quad Core) PHP 8450.00
Motherboard, lga1155 Asus P8H77-M LE PHP 3990.00
Vga Sapphire HD 7850 2gb 256bit gddr5 PHP 8500.00
Casing NZXT Phantom 410 (2 Tone) Mid Tower PHP 4485.00
Memory, Gskill Ripjaws X 8GB 4gbx2 DDR3 1600 CL9 PHP 2450.00
Hdd Internal, Seagate 2TB 7200rpm 64mb, ST2000DM001 (SATA 6 Gb/s) PHP 4590.00
Psu, Seasonic S12II-620w 80PLUS Bronze PHP 3300.00
Monitor Led, LG 23 inch LED IPS Panel, IPS234V PHP 7900.00
DVDrw Internal, Asus 24X DVDwriter SATA DRW-24B5ST PHP 950.00
Keyboard, A4Tech KR-8520D USB Desktop Combo PHP 420.00
Ups/Avr, PROTEC 500w AVR 3x220V / 1x110V PHP 250.00
Fan, Deepcool Ice Blade Fan 120mm, 4 Pin PHP 220.00*4= PHP 880
Accessory TV Bracket l Wall Mount PHP 350.00
