Need a cpu cooler (Air cooler)
Hi i need a cpu cooler, Oh I wonder if these fit in my system?
My specs:
Motherboard: asus crosshair v formula
Ram: Corsair Vengeance DDR3 1600MHz 16GB CL9
Cpu: Amd Fx8150
Psu: Corsair ax 850w
Gpu: Gainward Gtx 670
Hdd1: Western digital Black 1tb
Hdd2: Western digital green 1b
ssd: Ocz agility 120 gb
Pc Case: Corsair graphite 600 t ( Not windows version) Mesh version.
here is the coolers that i want:
ARCTIC Freezer A30 AMD ( UCACO-FA30001-GB )
ARCTIC Freezer 7 Pro Rev.2 (DCACO-FP701-CSA01)
ARCTIC Freezer 64 PRO ( UCACO-FP64101-BL )
ARCTIC Freezer 13 Pro ( UCACO-FZP13-BL )
ARCTIC Freezer 13 PRO CO ( UCACO-FP13100-BL)
ARCTIC Freezer XTREME Rev.2 ( UCACO-P0900-CSB01) /I want this cooler :) but I'm not sure if it fits.. :cry:
so please help me.. the stock cooler from amd is like a starfighter :whistle:
/Sorry for bad english- i am from norway :hello:
-Jarle
5 answers Last reply
More about need cooler cooler
  1. The Freezer Xtreme Rev 2 will fit fine in your case. A 600T is a boderline full tower and there are several reviews on Newegg indicating that it fits in most mid size towers.
    but the ram modules is very tall.. will the cooler fit with the ram modules ? :S i use all 4 ram slots..
  3. It depends how close your slots are to your CPU bracket. Its big but I think if you mount it so that the fan is pushing towards the back of your case, you should be fine.
    here you can see a picture. Motherboard: http://www.hardwareheaven.com/reviewimages/asus-crosshair-v-msi-990fx/asus-crosshair-v-990fx_board.jpg
    here you can see a picture off my stuff, cpu socket, and ram installed. hope this helps: https://dl.dropbox.com/u/45469438/20120928_170128.jpg
  5. It's hard to gauge from pictures. I haven't ever actually held the CPU cooler, so I can't tell you how big it is in person, but it's measurements are something like 110x100x130mm. You might just get a measuring tape out and see if it will fit in your board. Again, I think that if you put it in a push orientation facing the rear of your case, that it will fit fine.
Homebuilt Cooling Arctic CPUs Systems
