Just recently built a new computer. Here are my parts:
ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8150FRGUBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
MSI R7770-PMD1GD5 Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127687
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
OCZ Vertex 3 VTX3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227706
XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
COOLER MASTER Elite 431 Plus RC-431P-KWN2 Black Steel Body (0.5mm SECC), ABS plastic ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119256
2 Rosewill RFA-120-BL 120mm 4 Blue LEDs LED Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200049
Scythe DFS123812-3000 "ULTRA KAZE" 120 x 38 mm Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185054
So i installed Windows 7 64 bit Ultimate. My computer keeps on randomly freezing or resetting itself or just crashing completely. I also got blue screened yesterday. I installed all the drivers. My comp runs at CPU temp: 45C and MOBO temp: 31C idle. I don't know if those temperatures are high or not?
Also i have a problem with the windows update thing when it automatically does it when you shut down. So when i shut down it updates and turns off. Then when i boot my computer on next time it configures the updates from before but fails everytime, so everytime i turn off my computer now it loops and installs the same stuff i think and then fails when booting up my comp.
I don't know whats wrong with my computer? is it software or my MOBO or Processor?
sorry i dont have a lot of info but thanks for the help
