Closed Solved
Radeon HD 5770 crossfire problem ...
Hi Guys..
I'm running a sapphire Crossfire ATI Radeon HD 5770
Gigabyte GA-890GPA-UD3H
Phenom ii X4 3.2Ghz (overclocked to 3.5 with stock voltages)
In CPU Z I'm getting two different readings though
1st Radeon HD 5770 is giving me :
core: 399Mhz
Memory: 900Mhz
and 2nd Radeon HD 5770 is:
Core: 859 Mhz
Memory : 1200 mhz
Question..
Why?
Aren't they supposed to be equal?
Any help will be greatly appreciated. Thanks
NB: (I disabled AMD overdrive because the values were lower for the 1st video card)
Is there a chance that this is an error?
6 answers Last reply Best Answer
More about radeon 5770 crossfire problem
  1. Best answer
    maybe the first card is clocked down in 2d...run a game with GPUZ in the background and log to file...then exit out of the game and see if they are running the same speed....is crossfire enabled?
  2. Best answer selected by Markali_88.
  3. Ya I did.. My bad. Was running pcsx2 initially. Seems it doesn't support crossfire.
  4. Works with arkham asylum. Seems to be something like speedstep. Thanks.
  5. no prob glad it worked out
  6. This topic has been closed by Mousemonkey
Radeon Crossfire HD Graphics
