I am going to save up money and start building my first pc!!! I have picked out some parts i want to know if they are compatible and if you want to recommend anything else thats cool! I wont be doing hardcore gaming only mine craft and looking at videos. Thanks for your help and i am only looking to spend about $550 at the most.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811517015 case
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031 cd/dvd rom
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017 modular power suply
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148543 8gb of ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130653 motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115077 i3 2120 3.3ghz
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148221 harddrive 500gb
thanks for your help and feel free to recommend anything else or somthing i dont need i will be using windows 64 bit home edition also.
