[Solved] New Build Monitor - Hard Drive
I just had my system built, ran it the first time and i can't get the monitor screen to be full screen. It's a Samsung 24" LED Monitor, control panel>screen resolution> 1920x1080, i can't set it higher, the borders are quite visible and i'm unable get the full screen. The monitor is connected via HDMI cable to video card.
Additionally, i also have an internal hard drive but it's undetected, after booting the computer, hard drive is inaccessible, i don't see it, OS is installed on SSD and it works fine.
Any help would be appreciated.
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Asus P8Z77-V PRO ATX LGA1155 Motherboard
Memory: Corsair Vengeance 16GB (4 x 4GB) DDR3-1600 Memory
Storage: Samsung 830 Series 128GB 2.5IN SATA3 MCX SSD Drive
Storage: Seagate Barracuda 7200.12 500GB 3.5IN 16MB Cache SATA3 Internal Hard
Disk Drive HDD
Video Card: MSI GeForce GTX 660 Ti Power ED 1019MHZ 2GB 6.0GHZ GDDR5 2xDVI
HDMI Display Port PCI-E
Case: Zalman Z9 Plus ATX Mid Tower Case
Power Supply: OCZ ModXStream Pro 700W 80 PLUS Certified ATX12V / EPS12V Power Supply
Optical Drive: Asus DVDE818A7T/BLK/B/GEN CD Reader, DVD Writer
2 answers Last reply
More about solved build monitor hard drive
  1. Switch of the over/underscan in nvidia control panel to get the full size.
    Is the HDD detected in bios? Do you see it in disk management? Is it initalised / formated?
    Used Nvidia Control Panel to adjust the screen resolution. Solved !
    The disk was in disk management as unallocated space, set it as a new volume, working now. Solved !
    Thanks.
New Build Hard Drives Monitors Systems
