Hey so Ive assembled a list of parts for my build i just want to hear your guys thoughts on it and want to make sure everything is compatible and will fit in my case. I will be using this PC for gaming mostly. Im already over budget so Im going to buy most the parts now and probably save up for the graphics card for last since Im not 100% set on it yet although I do like this one. Ill probably use the disk drive out of my old tower to save a little on cost. Everything is from NewEgg and Im trying to buy most things in the next couple days to take advantage of them being on sale.
Heres the list:
APEVIA X-JUPITER-JR G-Type X-JPJGT-MG Metallic Grey SECC Steel Chassis ATX Mid Tower Computer Case
Item #: N82E16811144191
GIGABYTE GA-970A-D3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Item #: N82E16813128521
Mushkin Enhanced MKNSSDBRKT2535 2.5" to 3.5" drive adapter bracket
Item #: N82E16817812011
GIGABYTE GV-R787OC-2GD Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video ...
Item #: N82E16814125418
OCZ ModXStream Pro 700W Modular High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
Item #: N82E16817341018
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
Item #: N82E16820231428
OCZ Agility 3 AGT3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
Item #: N82E16820227726
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
Item #: N82E16819103727
Heres the list:
