Water cooling
Last response: in Components
February 12, 2013 11:48:44 AM
So guys, im wondering if the Thermaltake bigwater 760 plus is good. I am wanting to cool an i3 3220, quietly.
I want it to be future proof, and how well would it cool a i7 3770k(what i will be upgrading to)?
I have found one for £55, but i am at school and cant find the link :(
I have heard that it leaks, is this true? And if this is rubbish, what cheap solution would you suggest(under £60)
Sam
More about : water cooling
February 12, 2013 2:58:52 PM
I dont know if that would fit in my tensy case :(
but imma gunna get a new case soon so its ok :)
So thanks
Sam
February 12, 2013 3:19:39 PM
watercooling will cost a bit more
this is out in a few weeks
and looks really promising
high quality components
and upgradeable to add gpu cooling--more rads etc
or can be used as is just to cool the cpu
http://www.swiftech.com/H220.aspx
February 12, 2013 3:49:46 PM
that compared to a h100(i?)
Sam
February 12, 2013 6:17:15 PM
i would take that over a h100i every time
far higher quality pump--about 6w to the h100i 1.5w
far quieter
better quality all round
great mounting system
tried and tested block--swiftech have been in the watercooling game a long time
and the h100i cant be added to should you get the watercooling bug and decide to cool your gpu in the
future
or add more rads
also includes a 8 pwm splitter block which i hope they sell seperately
and their reps are more than happy to answer questions
http://www.overclock.net/t/1345816/various-swiftech-h22...
February 12, 2013 6:20:46 PM
Swftech 220 and Xspc's rs240 kits are the lowest you should look at for real watercooling,
Basically if your budget is under £140/$140, stick with highend aircoolers
Moto
