Today I bought another Gigabyte AMD 6850 to match my current Gigabyte AMD 6850.
I have successfully crossfired them, and installed(or so I think). The thing being, when I first put them in, and turned on crossfire, and ran MSI Kombuster benchmarking tool, I found that my second GPU would never really go past 20%, when both GPU's should be 100% to the limit.
I then tinkered around, and ended up reinstalling all AMD drivers. at this point, starting up kombuster, both GPU's go to full usage(99%), and I was quite happy, than some little spam updater I installed several months ago, and havent gotten rid of yet popped up, saying blah blah blah needed an update. I clicked back to the benchmarking tool, and my main GPU was still at 99% usage, but my secondary GPU pretty much cut off when the benchmark minimized, and never regained past 20% usage.
I than tried this again, starting off with 99/99, and after alt-tabbing out, and re-entering, it went back to 99% first GPU, and 20% max(fluxuates between 0-20%) again.
I know this is not kombuster problem, because both GPU's mostly rise in temperature together, but when it drops to 20%, its temperature doesnt rise as first, most of the time than lowering.
If anyone has a clue, please inform, all hardware is compatible. custom PC was built from specs provided by tom's hardware. All drivers up to date through use of catalyst automatic driver installer from their website, and live update 5 provided by MSI.
running win7.
update:
hardware specs:
FOLLOWING IS DATA FROM CPU-Z:
CPU-Z TXT Report
Binaries
CPU-Z version 1.61
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 2500K
Codename Sandy Bridge
Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
Core Speed 3392.3 MHz
Multiplier x FSB 34.0 x 99.8 MHz
Stock frequency 3300 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 33x
Max turbo ratio 37x
Max efficiency ratio 16x
Min Power 20 Watts
O/C bins unlimited
Ratio 1 core 37x
Ratio 2 cores 36x
Ratio 3 cores 35x
Ratio 4 cores 34x
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020105h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
TSC 3292.5
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 6 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000206A7 0x00100800 0x1F9AE3BF 0xBFEBFBFF
0x00000002 0x76035A01 0x00F0B0FF 0x00000000 0x00CA0000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x02C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300803 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x20202020 0x49202020 0x6C65746E 0x20295228
0x80000003 0x65726F43 0x294D5428 0x2D356920 0x30303532
0x80000004 0x5043204B 0x20402055 0x30332E33 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00001000 0x70012100
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040004
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x22232425
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x883B0000
MSR 0x000001FC 0x00000000 0x0004005D
MSR 0x00000601 0x18141494 0x80001FFF
MSR 0x00000602 0x18141494 0x80001FFF
MSR 0x00000606 0x00000000 0x000A1003
MSR 0x00000610 0x000083B0 0x001482F8
MSR 0x00000611 0x00000000 0x62819191
MSR 0x00000639 0x00000000 0x409DC0E6
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000614 0x00000000 0x00A002F8
MSR 0x0000019C 0x00000000 0x883B0000
MSR 0x000001A2 0x00000000 0x00621200
MSR 0x00000198 0x000027B6 0x00002300
MSR 0x00000199 0x00000000 0x00002500
CPU Thread 1
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020105h
CPUID
0x00000001 0x000206A7 0x02100800 0x1F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000002
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x000001B1 0x00000000 0x883A0000
MSR 0x00000611 0x00000000 0x628215F2
MSR 0x00000639 0x00000000 0x409E0870
MSR 0x0000019C 0x00000000 0x883A0000
MSR 0x00000198 0x00002697 0x00002400
CPU Thread 2
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01020105h
CPUID
0x00000001 0x000206A7 0x04100800 0x1F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000004
MSR 0x000001B1 0x00000000 0x883C0000
MSR 0x00000611 0x00000000 0x62829001
MSR 0x00000639 0x00000000 0x409E47F6
MSR 0x0000019C 0x00000000 0x883C0000
MSR 0x00000198 0x000025CA 0x00002300
CPU Thread 3
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01020105h
CPUID
0x00000001 0x000206A7 0x06100800 0x1F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000006
MSR 0x00000611 0x00000000 0x62831956
MSR 0x00000639 0x00000000 0x409E95AF
MSR 0x00000198 0x000025F3 0x00002200
Chipset
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel P67 rev. B3
Graphic Interface PCI-Express
PCI-E Link Width x8
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 8192 MBytes
Channels Dual
Memory Frequency 798.2 MHz (1:6)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 2T
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 19456
MCHBAR registers
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 4096 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number CMZ8GX3M2A1600C9
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.2
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-23 @ 444 MHz
JEDEC #2 7.0-7-7-19-27 @ 518 MHz
JEDEC #3 8.0-8-8-22-30 @ 592 MHz
JEDEC #4 9.0-9-9-24-34 @ 666 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.500 Volts
Min Cycle time 1.250 ns (800 MHz)
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-6-6-16-27-2T @ 533 MHz (1.500 Volts)
XMP #2 9.0-9-9-24-41-2T @ 800 MHz (1.500 Volts)
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00
10 6C 78 6C 3C 6C 11 20 95 00 05 3C 3C 01 2C 83 81
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 1F 11 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 02 9E 01 00 00 00 00 00 00 FC E5
80 43 4D 5A 38 47 58 33 4D 32 41 31 36 30 30 43 39
90 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0C 4A 01 12 01 08 01 08 00 2A 0A 5A 24 00 5A 5A
C0 5A 78 10 F0 95 3E 00 00 05 3C 3C 01 2C 3C 00 00
D0 10 00 24 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
Monitoring
Mainboard Model P67A-G43 (MS-7673) (0x000003EE - 0x52735B20)
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71889A
LPCIO Vendor ID 0x1934
LPCIO Chip ID 0x1005
Config Mode I/O address 0x4E
Config Mode LDN 0x4
Config Mode registers
00 FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 10 05 31 19 34 00 00 92 20 01 C0 30 10 08 00 00
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Fintek F71889A
Voltage 0 3.33 Volts [0xD0] (+3.3V)
Voltage 1 1.04 Volts [0x82] (CPU VCORE)
Voltage 2 1.87 Volts [0x75] (VIN2)
Voltage 3 1.40 Volts [0x77] (VIN3)
Voltage 4 5.80 Volts [0x8A] (+5V)
Voltage 5 8.18 Volts [0x5D] (+12V)
Voltage 6 2.10 Volts [0x83] (VIN6)
Voltage 7 3.23 Volts [0xCA] (VSB3V)
Voltage 8 3.23 Volts [0xCA] (VBAT)
Temperature 0 37°C (98°F) [0x25] (TMPIN0)
Temperature 1 55°C (131°F) [0x37] (TMPIN1)
Temperature 2 33°C (91°F) [0x21] (TMPIN2)
Fan 0 2140 RPM [0x2BD] (FANIN0)
Fan PWM 0 100 pc [0xFF] (CPU)
Fan PWM 1 65 pc [0xA6] (System Fan 1)
Fan PWM 2 65 pc [0xA6] (System Fan 2)
00 FF C3 00 01 01 FF FF 00 00 00 02 00 62 4C 00 30
10 00 00 00 00 00 00 06 FF FF FF FF FF FF FF FF FF
20 D1 7B 75 78 8A 5D 83 CA CA FF FF FF FF FF A6 A6
30 7A D7 FF FF FF FF C9 C8 75 85 FF FF FF FF FF 00
40 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
60 00 00 EE 00 FF FF 00 00 00 00 FF 08 40 24 FF 00
70 FF FF 24 FF 37 FF 21 FF 24 00 24 24 24 00 00 00
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF A8 FF
90 00 06 06 00 16 FF 17 FF 44 04 00 2A 55 05 99 0A
A0 02 BD 00 FF 03 FF 3C 32 28 1E FF FF 3C 3C 3C 0D
B0 0F FF 00 A6 03 FF 41 41 41 32 FF FF FF BF A6 1C
C0 0F FF 00 A6 03 FF 41 41 41 32 FF FF FF BF A6 1C
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 01 00
F0 00 00 00 00 00 00 33 FF 02 22 FF 00 FF 00 FF FF
Hardware monitor AMD ADL
Voltage 0 0.95 Volts [0x3B6] (VIN0)
Temperature 0 39°C (102°F) [0x27] (TMPIN0)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0100
Revision ID 0x09
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7681
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Vendor Dependant
Caps offset 0xE0
PCI registers
00 86 80 00 01 06 00 90 20 09 00 00 06 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 81 76
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00
50 03 00 00 00 0D 00 00 00 00 00 00 00 01 00 80 7F
60 01 00 00 E0 00 00 00 00 01 80 D1 FE 00 00 00 00
70 00 00 80 FF 01 00 00 00 00 0C 80 FF 7F 00 00 00
80 10 11 11 00 00 00 11 00 1A 00 00 00 00 00 00 00
90 01 00 80 FF 01 00 00 00 01 00 70 7F 02 00 00 00
A0 01 00 00 00 02 00 00 00 01 00 80 7F 02 00 00 00
B0 01 00 00 80 01 00 00 80 01 00 80 7F 01 00 00 80
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 09 00 0C 01 9E 88 80 C2 90 00 00 24 00 00 00 00
F0 00 00 00 00 00 00 00 00 B8 0F 06 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0101
Revision ID 0x09
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps class Subsystem Vendor
Caps offset 0x88
SubVendor ID 0x1462
SubSystem ID 0x7681
PCI capability
Caps class Power Management
Caps offset 0x80
Caps version 1.2
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x90
PCI capability
Caps class PCI Express
Caps offset 0xA0
Device type Root Port of PCI-E Root Complex
Port 2
Version 2.0
Physical slot #0
Presence detect yes
Link width 8x (max 8x)
Extended capabilities
Caps class Virtual Channel
Caps offset 0x100
Caps class Root Complex Link Declaration
Caps offset 0x140
Link Entries # 1
Port Number 2
PCI registers
00 86 80 01 01 07 00 10 00 09 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 01 01 00 E0 E0 00 20
20 60 FE 60 FE 01 C0 F1 CF 00 00 00 00 00 00 00 00
30 00 00 00 00 88 00 00 00 00 00 00 00 10 01 18 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A
80 01 90 03 C8 08 00 00 00 0D 80 00 00 62 14 81 76
90 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 10 00 42 01 00 80 00 00 00 00 00 00 82 20 21 02
B0 40 00 82 D0 00 00 04 00 00 00 48 00 00 00 00 00
C0 00 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00
D0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 01 00 00 00 00 00 00 00 10 00
100 02 00 01 14 00 00 00 00 00 00 00 00 00 00 00 00
110 01 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x0105
Revision ID 0x09
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x88
SubVendor ID 0x1462
SubSystem ID 0x7681
PCI capability
Caps offset 0x80
Caps version 1.2
PCI capability
Caps offset 0x90
PCI capability
Caps offset 0xA0
Port 3
Version 2.0
Physical slot #0
Presence detect yes
Caps offset 0x100
Caps offset 0x140
Link Entries # 1
Port Number 3
PCI registers
00 86 80 05 01 07 00 10 00 09 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 02 02 00 D0 D0 00 20
20 50 FE 50 FE 01 B0 F1 BF 00 00 00 00 00 00 00 00
30 00 00 00 00 88 00 00 00 00 00 00 00 10 01 00 00
A0 10 00 42 01 00 80 00 00 00 00 00 00 82 20 21 03
B0 40 00 81 D0 00 00 04 00 00 00 48 00 00 00 00 00
Description Communication Device
Location bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C3A
Revision ID 0x04
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE707000
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x8C
PCI registers
00 86 80 3A 1C 06 00 10 00 04 00 80 07 00 00 80 00
10 04 70 70 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 73 76
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
40 55 02 00 1E 08 00 01 80 06 00 00 66 F8 1F 00 10
50 01 8C 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 05 00 80 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 C0
C0 F6 2B 5A 75 02 BC B8 05 09 46 B9 33 78 E5 79 E1
D0 57 19 D6 A9 A8 EB 26 17 EC 37 F4 DB D7 7A 52 BF
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C2D
Revision ID 0x05
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE706000
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 2D 1C 06 00 90 02 05 20 03 0C 00 00 00 00
10 00 60 70 FE 00 00 00 00 00 00 00 00 00 00 00 00
50 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
60 20 20 FF 07 00 00 00 00 01 00 00 00 00 20 00 C0
70 00 00 DF 3F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 80 00 11 88 0C 93 30 0D 00 24 00 00 00 00
90 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 02 20 04 00 02 31 00 D0 04 60 83 7E
F0 00 00 00 00 88 85 80 00 87 0F 05 08 E8 17 5B 20
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C20
Revision ID 0x05
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE700000
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x70
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
Caps offset 0x100
Caps offset 0x130
Link Entries # 1
Port Number 15
PCI registers
00 86 80 20 1C 06 00 10 00 05 00 03 04 10 00 00 00
10 04 00 70 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
40 01 00 00 05 00 00 00 00 00 00 00 00 00 80 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 10 00 00 10 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 04 00 01 00 24 00 40 00 0C A3 82 10 00 33 02
D0 00 0C A3 02 10 00 33 02 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 87 0F 05 08 00 00 00 00
100 02 00 01 13 01 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 22 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00
130 05 00 01 00 00 01 00 0F 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C10
Revision ID 0xB5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x40
Port 1
Version 2.0
Physical slot #0
Presence detect no
Link width 0x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7673
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
00 86 80 10 1C 04 00 10 00 B5 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 03 03 00 F0 00 00 20
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 11 01 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 12 4C 11 01
50 00 00 01 10 00 B2 04 00 00 00 00 00 00 00 00 00
60 00 00 00 00 16 00 00 00 00 00 00 00 00 00 00 00
70 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0D A0 00 00 62 14 73 76 00 00 00 00 00 00 00 00
A0 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 01 00 0B 00 00 00 80 11 01 00 00 00 00
E0 00 3F 00 00 00 00 00 00 03 00 00 00 00 00 00 00
100 00 00 00 00 00 00 00 00 00 00 00 00 11 00 06 00
110 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 4 (0x04)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xB5
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x40
Port 5
Version 2.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7673
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
00 86 80 4E 24 07 00 10 00 B5 01 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 04 05 00 F0 00 00 20
40 10 80 42 01 00 80 00 00 00 00 10 00 12 4C 11 05
50 00 00 11 30 00 B2 24 00 00 00 40 01 00 00 00 00
E0 00 3F 00 00 00 00 00 00 03 00 00 00 03 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x1C1A
Revision ID 0xB5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x06
Int. Line 0x10
Int. Pin 0x02
PCI capability
Caps offset 0x40
Port 6
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7673
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
00 86 80 1A 1C 06 00 10 00 B5 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 06 06 00 F0 00 00 00
20 40 FE 40 FE F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 10 02 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 12 3C 11 06
50 40 00 12 70 00 B2 2C 00 00 00 40 01 00 00 00 00
70 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 03 00 00 00 00 00 00 03 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 6 (0x06)
Common header
Vendor ID 0x8086
Model ID 0x1C1C
Revision ID 0xB5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x07
Int. Line 0x12
Int. Pin 0x03
PCI capability
Caps offset 0x40
Port 7
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7673
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
00 86 80 1C 1C 07 00 10 00 B5 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 07 07 00 C0 C0 00 00
20 F0 FF 00 00 01 D0 01 D0 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 12 03 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 12 3C 11 07
50 40 00 11 70 00 B2 34 00 00 00 40 01 00 00 00 00
A0 01 00 02 C8 00 01 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C26
Revision ID 0x05
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE705000
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 26 1C 06 00 90 02 05 20 03 0C 00 00 00 00
10 00 50 70 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 04 20 05 7E
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C46
Revision ID 0x05
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xE0
PCI registers
00 86 80 46 1C 07 00 10 02 05 00 01 06 00 00 80 00
40 01 04 00 00 80 00 00 00 01 05 00 00 10 00 00 00
50 F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 8B 8A 85 8B D0 00 00 00 80 80 83 87 F8 F0 00 00
70 78 F0 79 F0 7A F0 7B F0 7C F0 7D F0 7E F0 7F F0
80 10 00 0F 3F 01 0A FC 00 91 02 FC 00 91 02 0C 00
90 01 0A 0C 00 00 0F 00 00 00 00 00 00 00 00 00 00
A0 08 0A A0 00 49 18 06 00 00 47 00 00 00 03 00 00
B0 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00
D0 33 22 11 00 67 45 00 00 C0 FF 00 00 00 00 00 00
E0 09 00 0C 10 00 00 00 00 93 02 64 0C 00 00 00 00
F0 01 C0 D1 FE 00 00 00 00 87 0F 05 08 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x1C00
Revision ID 0x05
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000F090
Address 5 (port) 0x0000F080
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x0B
Int. Pin 0x02
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x13
Caps offset 0xB0
PCI registers
00 86 80 00 1C 05 00 B0 02 05 8A 01 01 00 00 00 00
10 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
20 91 F0 00 00 81 F0 00 00 00 00 00 00 62 14 73 76
30 00 00 00 00 70 00 00 00 00 00 00 00 0B 02 00 00
40 00 80 03 A3 00 00 00 00 04 00 00 01 00 00 00 00
50 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00
70 01 B0 03 00 08 00 00 00 00 00 00 00 00 00 00 00
80 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 0D 02 82 83 01 00 0D 08 42 5C 01 00 00 00 00
A0 E0 00 00 00 00 00 39 00 00 00 00 00 00 00 00 00
B0 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x1C22
Revision ID 0x05
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE704000
Address 4 (port) 0x0000F000
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x05
Int. Pin 0x03
PCI registers
00 86 80 22 1C 03 00 80 02 05 00 05 0C 00 00 00 00
10 04 40 70 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 01 F0 00 00 00 00 00 00 00 00 00 00 62 14 73 76
30 00 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x1C08
Revision ID 0x05
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000F070
Address 1 (port) 0x0000F060
Address 2 (port) 0x0000F050
Address 3 (port) 0x0000F040
Address 4 (port) 0x0000F030
Address 5 (port) 0x0000F020
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x13
Caps offset 0xB0
PCI registers
00 86 80 08 1C 05 00 B0 02 05 85 01 01 00 00 00 00
10 71 F0 00 00 61 F0 00 00 51 F0 00 00 41 F0 00 00
20 31 F0 00 00 21 F0 00 00 00 00 00 00 62 14 73 76
30 00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
40 07 A3 07 A3 00 00 00 00 05 00 01 01 00 00 00 00
50 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00
90 00 00 03 03 00 00 00 00 00 00 00 00 00 00 00 00
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x6739
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xC0000000
Address 2 (memory) 0xFE620000
Address 4 (port) 0x0000E000
Subvendor ID 0x1458
Subsystem ID 0x21F8
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Device type Legacy PCI-E Endpoint Device
Port 0
Version 2.0
Link width 8x (max 16x)
PCI capability
Caps offset 0xA0
Caps class Vendor Specific
Caps offset 0x100
Vendor ID 1
Size 16
Caps class Advanced Error Reporting
Caps offset 0x150
PCI registers
00 02 10 39 67 07 04 10 00 00 00 00 03 10 00 80 00
10 0C 00 00 C0 00 00 00 00 04 00 62 FE 00 00 00 00
20 01 E0 00 00 00 00 00 00 00 00 00 00 58 14 F8 21
30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 58 14 F8 21
50 01 58 03 06 00 00 00 00 10 A0 12 00 A1 8F 00 00
60 00 29 09 00 02 0D 00 00 40 00 82 10 00 00 00 00
80 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00
A0 05 00 81 00 0C F0 E0 FE 00 00 00 00 73 49 00 00
100 0B 00 01 15 01 00 01 01 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0xAA88
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE640000
Subvendor ID 0x1458
Subsystem ID 0xAA88
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x150
PCI registers
00 02 10 88 AA 06 00 10 00 00 00 03 04 10 00 80 00
10 04 00 64 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 88 AA
30 00 00 00 00 50 00 00 00 00 00 00 00 11 02 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 58 14 88 AA
A0 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x6739
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xB0000000
Address 2 (memory) 0xFE5E0000
Address 4 (port) 0x0000DF00
Subvendor ID 0x1458
Subsystem ID 0x21F8
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 1
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x150
PCI registers
00 02 10 39 67 06 04 10 00 00 00 00 03 10 00 80 00
10 0C 00 00 B0 00 00 00 00 04 00 5E FE 00 00 00 00
20 01 DF 00 00 00 00 00 00 00 00 00 00 58 14 F8 21
60 00 29 09 00 02 0D 00 01 40 00 81 10 00 00 00 00
80 00 00 00 00 00 00 00 00 02 00 01 00 00 00 00 00
A0 05 00 81 00 0C F0 E0 FE 00 00 00 00 B0 49 00 00
Location bus 2 (0x02), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0xAA88
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE540000
Subvendor ID 0x1458
Subsystem ID 0xAA88
Int. Line 0x12
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 1
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x150
PCI registers
10 04 00 54 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 12 02 00 00
80 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x1080
Revision ID 0x01
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x04
Secondary bus 0x05
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x78
Caps version 1.2
PCI capability
Caps offset 0x80
Device type PCI-E to PCI/PCI-X bridge
Port 1
Version 1.0
PCI capability
Caps offset 0xC0
SubVendor ID 0x1462
SubSystem ID 0x7673
Caps offset 0x100
PCI registers
00 21 1B 80 10 04 00 10 00 01 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 04 05 05 20 F1 01 20 20
40 20 00 00 00 00 0F 00 00 00 00 00 00 A7 27 00 00
50 05 78 80 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 11 78 01 00 00 00 00 00
70 00 00 00 00 00 00 00 00 01 80 23 FE 08 00 00 00
80 10 C0 71 00 00 80 90 05 00 28 0A 00 11 DC 00 01
90 00 00 11 00 00 00 00 00 C0 03 00 00 00 00 00 00
C0 0D 00 00 00 62 14 73 76 00 00 00 00 00 00 00 00
100 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller
Location bus 6 (0x06), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1033
Model ID 0x0194
Revision ID 0x04
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE400000
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x70
PCI capability
Caps class MSI-X
Caps offset 0x90
PCI capability
Caps offset 0xA0
Device type PCI-E Endpoint Device
Port 0
Version 2.0
Caps offset 0x100
Caps class Device Serial Number
Caps offset 0x140
Caps class 0x18
Caps offset 0x150
PCI registers
00 33 10 94 01 06 04 10 00 04 30 03 0C 10 00 00 00
10 04 00 40 FE 00 00 00 00 00 00 00 00 00 00 00 00
50 01 70 C3 C9 08 00 00 00 00 00 00 00 00 00 00 00
60 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 05 90 86 00 00 00 00 00 00 00 00 00 00 00 00 00
90 11 A0 07 80 00 10 00 00 80 10 00 00 00 00 00 00
A0 10 00 02 00 C0 8F 00 00 00 28 19 00 12 EC 07 00
B0 40 01 12 10 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 10 08 00 00 00 00 00 00 00 00 00 00
E0 FC 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 08 14 60 00 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 14 00 00 00 00 00 00 00 00 30 20 06 00
110 00 20 00 00 00 20 00 00 00 00 00 00 00 00 00 00
Description Ethernet Controller
Location bus 7 (0x07), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x06
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000C000
Address 2 (memory) 0xD0004000
Address 4 (memory) 0xD0000000
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Port 0
Version 2.0
PCI capability
Caps class MSI-X
Caps offset 0xB0
PCI capability
Caps class Virtual Product Data
Caps offset 0xD0
Caps offset 0x100
Caps offset 0x140
Caps offset 0x160
PCI registers
00 EC 10 68 81 07 04 10 00 06 00 00 02 10 00 00 00
10 01 C0 00 00 00 00 00 00 0C 40 00 D0 00 00 00 00
20 0C 00 00 D0 00 00 00 00 00 00 00 00 62 14 73 76
30 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
40 01 50 C3 FF 08 01 00 00 00 00 00 00 00 00 00 00
50 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 B0 02 02 C1 8C 90 05 00 50 10 00 11 3C 07 00
80 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 10 00 00 00 10 00 00 00 00 00 00 00
B0 11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00
D0 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110 00 20 00 00 00 20 00 00 A0 00 00 00 00 00 00 00
DMI
BIOS Type American Megatrends
DMI BIOS
vendor American Megatrends Inc.
version V1.18
date 02/22/2012
ROM size 8192 KB
DMI System Information
manufacturer MSI
product MS-7673
version 2.0
serial To be filled by O.E.M.
UUID {00000000-0000-0000-0000-6C626D441D13}
DMI Baseboard
vendor MSI
model P67A-G43 (MS-7673)
revision 2.0
DMI System Enclosure
manufacturer MSI
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Port Connector
designation J1A1 (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation J2A2A (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation J3A1 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation J5A1 (internal)
designation LAN (external)
port type Network Port
connector RJ-45
DMI Port Co
running win7.
update:
hardware specs:
CPU-Z TXT Report
Binaries
CPU-Z version 1.61
Processors
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Processor 1 ID = 0
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
FID/VID Control yes
Max turbo ratio 37x
Min Power 20 Watts
O/C bins unlimited
Ratio 1 core 37x
Ratio 2 cores 36x
Ratio 3 cores 35x
Ratio 4 cores 34x
Thread dumps
CPU Thread 0
APIC ID 0
Type 01020105h
TSC 3292.5
CPUID
CPU Thread 1
APIC ID 2
Type 01020105h
CPUID
CPU Thread 2
APIC ID 4
Type 01020105h
CPUID
CPU Thread 3
APIC ID 6
Type 01020105h
CPUID
Chipset
PCI-E Link Width x8
Memory Type DDR3
Channels Dual
MCHBAR registers
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 1
SPD registers
DIMM # 2
SPD registers
Monitoring
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71889A
Config Mode LDN 0x4
Hardware Monitors
PCI Devices
Common header
Vendor ID 0x8086
Model ID 0x0100
Revision ID 0x09
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7681
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xE0
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x0101
Revision ID 0x09
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x88
SubVendor ID 0x1462
SubSystem ID 0x7681
PCI capability
Caps offset 0x80
Caps version 1.2
PCI capability
Caps offset 0x90
PCI capability
Caps offset 0xA0
Port 2
Version 2.0
Physical slot #0
Presence detect yes
Caps offset 0x100
Caps offset 0x140
Link Entries # 1
Port Number 2
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x0105
Revision ID 0x09
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x88
SubVendor ID 0x1462
SubSystem ID 0x7681
PCI capability
Caps offset 0x80
Caps version 1.2
PCI capability
Caps offset 0x90
PCI capability
Caps offset 0xA0
Port 3
Version 2.0
Physical slot #0
Presence detect yes
Caps offset 0x100
Caps offset 0x140
Link Entries # 1
Port Number 3
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C3A
Revision ID 0x04
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x8C
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C2D
Revision ID 0x05
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C20
Revision ID 0x05
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x70
Port 0
Version 1.0
Caps offset 0x100
Caps offset 0x130
Link Entries # 1
Port Number 15
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C10
Revision ID 0xB5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x40
Port 1
Version 2.0
Physical slot #0
Presence detect no
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7673
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xB5
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x40
Port 5
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7673
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C1A
Revision ID 0xB5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x06
Int. Line 0x10
Int. Pin 0x02
PCI capability
Caps offset 0x40
Port 6
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7673
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C1C
Revision ID 0xB5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x07
Int. Line 0x12
Int. Pin 0x03
PCI capability
Caps offset 0x40
Port 7
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7673
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C26
Revision ID 0x05
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C46
Revision ID 0x05
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xE0
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C00
Revision ID 0x05
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x0B
Int. Pin 0x02
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x13
Caps offset 0xB0
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C22
Revision ID 0x05
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x05
Int. Pin 0x03
PCI registers
Common header
Vendor ID 0x8086
Model ID 0x1C08
Revision ID 0x05
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x13
Caps offset 0xB0
PCI registers
Common header
Vendor ID 0x1002
Model ID 0x6739
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x21F8
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x150
PCI registers
Common header
Vendor ID 0x1002
Model ID 0xAA88
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0xAA88
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x150
PCI registers
Common header
Vendor ID 0x1002
Model ID 0x6739
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x21F8
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 1
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x150
PCI registers
Common header
Vendor ID 0x1002
Model ID 0xAA88
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0xAA88
Int. Line 0x12
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 1
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x150
PCI registers
Common header
Vendor ID 0x1B21
Model ID 0x1080
Revision ID 0x01
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x04
Secondary bus 0x05
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x78
Caps version 1.2
PCI capability
Caps offset 0x80
Port 1
Version 1.0
PCI capability
Caps offset 0xC0
SubVendor ID 0x1462
SubSystem ID 0x7673
Caps offset 0x100
PCI registers
Common header
Vendor ID 0x1033
Model ID 0x0194
Revision ID 0x04
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x70
PCI capability
Caps class MSI-X
Caps offset 0x90
PCI capability
Caps offset 0xA0
Port 0
Version 2.0
Caps offset 0x100
Caps offset 0x140
Caps class 0x18
Caps offset 0x150
PCI registers
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x06
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7673
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Port 0
Version 2.0
PCI capability
Caps class MSI-X
Caps offset 0xB0
PCI capability
Caps offset 0xD0
Caps offset 0x100
Caps offset 0x140
Caps offset 0x160
PCI registers
DMI
DMI BIOS
version V1.18
date 02/22/2012
ROM size 8192 KB
manufacturer MSI
product MS-7673
version 2.0
DMI Baseboard
vendor MSI
revision 2.0
manufacturer MSI
DMI Port Connector
connector PS/2
DMI Port Connector
connector PS/2
DMI Port Connector
connector DB-9 male
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
connector RJ-45
DMI Port Co
