Hello,
Trying to find an answer before i leave work so i can pick up the right cable on the way home.
So f'in annoying.
I got this: http://www.amazon.com/Accell-B087B-006B-DisplayPort-Single-Link-Certified/dp/B004071ZXA
sadly, the link i read for my monitor, said dvi-d but i found a working link at teh samsung site (P2770H) and the link says the monitor is dvi-i.
SO now, learned that dvi-i looks different than dvi-i but the adapter is only dvi-d.
Now, this is my 3rd monitor. But it came with no cable. I want to know, if i buy a dvi-d to dvi-d monitor cable, can the dvi-d cable fit and work on a monitor that is dvi-i?
i think shape wise, it should fit, but will it work? or do i have to call samsung to ask?
Regards,
Sanjay
So f'in annoying.
Regards,
Sanjay
