Fan Problem?
August 9, 2012 3:51:20 PM
About ~6 months ago I built my PC, and recently there has been a problem with what I suspect to be the GPU fan. So far it's happened twice with about a 3 or 4 day interval. What happens is, my monitor goes completely blank, sound starts skipping, and the GPU makes a high pitched whirring noise. The computer pretty much locks up. I can't turn it off, so I have to manually unplug it from the wall. I'm hoping someone can help me with this problem?
My GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
I am also on driver version 296.10
More about : fan problem
a b U Graphics card
August 9, 2012 4:55:04 PM
I would update drivers before doing anything to big. If that doesn't work, try underclocking and see if it is stable there. If it is stable underclocked I would RMA but that is your choice
m
l
August 10, 2012 4:04:51 PM
Ok, I installed the latest drivers. If the problem occurs again, I'll need some help, I'm not certain on how to underclock.
m
l
