HELP! Just got my HD 6950 Sapphire but have power connections question
Hello guys previously I asked what card I should upgrade to and since the ATI Radeon HD 6950 was on sale I opted for it... Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102987
Now I got the card in my PCI Express Slot and have it locked into place but I'm not sure If I'm good plugging one 6 pin connector ( 3 on top 3 on bottom ) into one of the 6 pin slots on the card when there is 2.
I know on the bag the card was in it says the following:
STOP
You Must connect
this graphics board to
the computers
power supply.
My PSU is 900w Antek for the record.
Then in the numbered diagram it goes as following.
1 Graphics card
2 Power supply
3 Power cable connectors
4 Graphics card power connectors
5 Power connectors to the graphics card
6 Power cable from power supply
And it shows pictures and all and there is a box for number ( 4 ) that says
Connector(s) option:
1x4 pin, 1x6 pin, 1x8 pin,
2x4pin,2x6 pin, 2x8 pin, 1x8 pin+1x6 pin.
So far I can only plug in 1x6 pin so am I good with just that one plugged into the card when there is another 6 pin open?
For number 5 there is a box that says
1x4 pin, 1x6 pin, 1x8 pin, 2x4pin, 2x6pin,2x8 pin,1x8 pin+1x6 pin.
I'm just really confused... I have 1x6 pin plugged in which is that plug with 3ontop and 3 onbottom... which is what my old gpu used a Ati Radeon HD 5750.
3 answers Last reply
More about help 6950 sapphire power connections question
  1. you need to connect 2 six pin connectors,the card wont work with only one 6 pin connector.....
  2. The 6950 is different to your old 5750. It needs two 6-pin (2x3) PCI-E Connectors to work and it will not work if you put only one.
    This is your PSU right?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371050
    You should have another 6 (2x3) pin PCI-E connector.
  3. HCG-900 ?
    http://store.antec.com/Product/power_supply-high_current_gamer/hcg-900/0-761345-23890-8.aspx
    Quote:
    Four gold-plated 8 (6+2)-pin PCI-E connectors for multiple-graphics card configurations
    Quote:
    PCI-Express Connector 4 x 6+2-Pin
    Looks like you have 4 of them.... you plug the 6 in and leave the other 2 dangling.
    Ya card is in a PCI-E slot so ya plug in the ones that say PCI-E on them
Graphics Cards Power HD Graphics Product
