So I thought I would upgrade my Pentium II 400 Mhz Gateway computer and bought an ECS K7S5A SiS® 735 Socket A Motherboard with an Athlon Thunderbird 1.4GHz 266MHz FSB Processor and a 40GB hard drive from Western Digital. Stuff is in the mail as we speak. In preparation, I open up my computer and find a 200W power supply. Given that I have filled every bay, PCI slot, and IDE slot, I guess I am lucky it still works. Long and short, I need a new power supply. So here are my questions:
1) Can I get away with just replacing the power supply and retain the case to reinstall the new motherboard or would I be better off buying a whole new case and power supply?
2) If I can buy a power supply alone, what product and wattage do you recommend considering the best performance given price? Where can I buy it?
3) If I should buy a new case as well, what then would you recommend? I see lots of deal out there for cheap case/power supply combos but I want to know what I am getting. Do you recommend any particular combo from any particular store?
Thanks!
Thanks!
