Solved
Help With Connections
So i just got done building my little brother his own computor but i ran across a slight bit of confusion. The Graphics card i got (EVGA GTX480) requires a 8pin and 6 pin connection. But with the PSU i bought (XION 850W) the 8pin connector wont fit due to the different shapes of the pins. How else would i go about connecting the Graphics card? Thanks alot
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130759
http://www.amazon.com/Xion-Performance-Watts-Supply-XON-850P14F/dp/B005HNF1EA/ref=sr_1_2?ie=UTF8&qid=1344545641&sr=8-2&keywords=XION+850W
4 answers Last reply Best Answer
More about help connections
  1. Best answer
    You are trying to use the wrong connector. there are 2 X 6 +2 Pin PCIE connectors so that's a block of 6 with 2 extra hanging from them. these are the Graphics card power cables. Push the two extra up to make 8 and use those ones.
    I believe you are trying to use the CPU power connector.
    Mactronix :)
  2. Yes that should be true, you're not using the proper connectors. The PCI-E 8-pin plug is the 6+2Pin one.
  3. Best answer selected by Shmister.
  4. That makes sense. oops i totally neglected the cpu power or else it would have been clear to me on which to use :). Its nice knowing you can always count on a forum like this to help you through even the slightest mess ups. Thanks Mactronix
Graphics Cards Connection Brother Graphics Product
